1577.2
1577.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1577.2 数据手册
Data sheet 1577.2 RK 2,5-4/35 BG Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Business data Article number 1577.2 Article name RK 2,5-4/35 BG GTIN (EAN) 4044211047566 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 9.6 g Weight per piece (including packaging) 10.12 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 1577.2 Product description Feed-through terminal Creation date 17.12.2023 17:43:59 Subject to technical changes 1 Data sheet 1577.2 RK 2,5-4/35 BG Technical data Dimensions Length 48 mm Width 6 mm Height TS 35/7.5 47 mm Ratings Rated voltage 800 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 11 Stripping length 12 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 17:43:59 Subject to technical changes 2 Data sheet 1577.2 RK 2,5-4/35 BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Conform Yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No Creation date 17.12.2023 17:43:59 Subject to technical changes 3 Data sheet 1577.2 RK 2,5-4/35 BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 32 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 10 CSA stripping length 12 mm CSA File Number 042110_0_000 CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 32 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 10 CSAus stripping length 12 mm CSAus File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 6 mm² KEMA torque, min. 0.5 Nm KEMA torque, max. 1 Nm Creation date 17.12.2023 17:43:59 Subject to technical changes 4 Data sheet 1577.2 RK 2,5-4/35 BG Media Creation date 17.12.2023 17:43:59 Subject to technical changes 5 Data sheet 1577.2 RK 2,5-4/35 BG Accessories Cover Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2494.0 AD 4/24/B/E YE 4044211052959 50 ST Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2011.0 AD 4/24/B YE 4044211048143 50 ST Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2493.0 AD 4/24/B/E YE 4044211052942 50 ST Cover, Length: 26.5 mm, Width: 6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2953.0 AD 1/6/B YE 4044211056810 50 ST Cover, Length: 26.5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 2965.0 AD 1/6 WH 4044211056940 50 ST Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2079.0 AD 4/24/B YE 4044211048877 50 ST End plate Creation date 17.12.2023 17:43:59 Subject to technical changes 6 Data sheet 1577.2 RK 2,5-4/35 BG End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2001.2 AP 2,5-10 BG 4044211047979 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 21.9 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2742.2 QI 4 YE 4044211054823 20 ST Insulated cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2743.2 QI 10 YE 4044211054830 10 ST Insulated cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2740.2 QI 2 YE 4044211054809 50 ST Creation date 17.12.2023 17:43:59 Subject to technical changes 7 Data sheet 1577.2 RK 2,5-4/35 BG Insulated cross-connector Insulated cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.5 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2741.2 QI 3 YE 4044211054816 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2003.2 TRS 1 BG 4044211048068 100 Partition plate Partition plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2002.2 TW 2,5-10 BG 4044211048044 50 Creation date 17.12.2023 17:43:59 Subject to technical changes 8 Data sheet 1577.2 RK 2,5-4/35 BG Test adapters Test adapter, Length: 37.3 mm, Pitch size: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2813.0 TA 6/1/ST 4044211055400 10 ST Creation date 17.12.2023 17:43:59 Subject to technical changes 9
1577.2 价格&库存
很抱歉,暂时无法提供与“1577.2”相匹配的价格&库存,您可以联系我们找货
