15778.2
15778.2
    CONTA-CLIP
    INSULATED EXTERNAL CROSS CONNECT
15778.2 数据手册
Data sheet 15778.2 AQI/PRS/6 BK External cross-connector insulated, for relay socket base PRS 4/6-pole, can be shortened, Voltage: 250 V, Current: 10 A Business data Article number 15778.2 Article name AQI/PRS/6 BK GTIN (EAN) 4044211133993 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 5.4 g Weight per piece (including packaging) 5.52 g Unit of weight G Customs number 85389099 Country of origin PL Product description Insulated external cross-connector Creation date 16.12.2023 20:27:41 Subject to technical changes 1 Data sheet 15778.2 AQI/PRS/6 BK Technical data Connection data No. of poles 6 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:27:41 Subject to technical changes 2 Data sheet 15778.2 AQI/PRS/6 BK Media Creation date 16.12.2023 20:27:41 Subject to technical changes 3 Data sheet 15778.2 AQI/PRS/6 BK Accessories ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for industrial relay with 4 CO contacts, Screw connection, Plugin option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15137.2 PRS 4 4044211046200 1 ST Relay socket base PRS, for industrial relay with 4 CO contacts, Screw connection, Plugin option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15324.2 PRS 4 G 4044211047139 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15731.2 PRSU 4G/110V DC 4044211138516 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15167.2 PRSU 4/12V DC 4044211080853 5 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15168.2 PRSU 4/24V AC 4044211080877 10 ST Creation date 16.12.2023 20:27:41 Subject to technical changes 4 Data sheet 15778.2 AQI/PRS/6 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15726.2 PRSU 4/110V DC 4044211138462 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base and power contact relay, 4 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15622.2 PRSU 4G/24V DC eco 4044211121518 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base and power contact relay, 4 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15619.2 PRSU 4/24V DC eco 4044211121495 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 60 VDC Article number Article name GTIN (EAN) Packaging unit 15725.2 PRSU 4/60V DC 4044211138455 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 60 VDC Article number Article name GTIN (EAN) Packaging unit 15730.2 PRSU 4G/60V DC 4044211138509 1 ST Creation date 16.12.2023 20:27:41 Subject to technical changes 5 Data sheet 15778.2 AQI/PRS/6 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15421.2 PRSU 4G/12V DC 4044211080884 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 220 VDC Article number Article name GTIN (EAN) Packaging unit 15727.2 PRSU 4/220V DC 4044211138479 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base and power contact relay, 4 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15621.2 PRSU 4/230V AC eco 4044211121525 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base and power contact relay, 4 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15622.2 PRSU 4G/24V DC eco 4044211121518 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base with multi-layer gold contact, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16127.2 PRSU 4/24V DC Au 4044211178215 5 ST Creation date 16.12.2023 20:27:41 Subject to technical changes 6 Data sheet 15778.2 AQI/PRS/6 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base with multi-layer gold contact, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16399.2 PRSU 4G/24 V DC Au 4044211216504 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15733.2 PRSU 4G/115V AC 4044211138530 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15332.2 PRSU 4G/24V DC 4044211080723 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15371.2 PRSU 4G/24V AC 4044211080907 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15372.2 PRSU 4G/230V AC 4044211080730 10 ST Creation date 16.12.2023 20:27:41 Subject to technical changes 7 Data sheet 15778.2 AQI/PRS/6 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 12 VAC Article number Article name GTIN (EAN) Packaging unit 15392.2 PRSU 4/12V AC 4044211080860 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base and power contact relay, 4 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15623.2 PRSU 4G/24V AC eco 4044211121532 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base and power contact relay, 4 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15624.2 PRSU 4G/230V AC eco 4044211121549 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15724.2 PRSU 4/48V DC 4044211138448 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15726.2 PRSU 4/110V DC 4044211138462 1 ST Creation date 16.12.2023 20:27:41 Subject to technical changes 8 Data sheet 15778.2 AQI/PRS/6 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 220 VDC Article number Article name GTIN (EAN) Packaging unit 15727.2 PRSU 4/220V DC 4044211138479 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15728.2 PRSU 4/115V AC 4044211138486 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15729.2 PRSU 4G/48V DC 4044211138493 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 60 VDC Article number Article name GTIN (EAN) Packaging unit 15730.2 PRSU 4G/60V DC 4044211138509 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15733.2 PRSU 4G/115V AC 4044211138530 1 ST ##INVERSE##CONTA-ELECTRONICS Creation date 16.12.2023 20:27:41 Subject to technical changes 9 Data sheet 15778.2 AQI/PRS/6 BK Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 4 CO contacts, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15421.2 PRSU 4G/12V DC 4044211080884 1 ST Creation date 16.12.2023 20:27:41 Subject to technical changes 10
15778.2 价格&库存
很抱歉,暂时无法提供与“15778.2”相匹配的价格&库存,您可以联系我们找货
    • 1+58.888971+7.38479
