15779.2
15779.2
    CONTA-CLIP
    INSULATED EXTERNAL CROSS CONNECT
15779.2 数据手册
Data sheet 15779.2 AQI/PRS/8 BK External cross-connector insulated, for relay socket base PRS 1 and PRS 2/6-pole, can be shortened, Voltage: 250 V, Current 10 A Business data Article number 15779.2 Article name AQI/PRS/8 BK GTIN (EAN) 4044211134006 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 5.1 g Weight per piece (including packaging) 5.22 g Unit of weight G Customs number 85389099 Country of origin PL Product description Insulated external cross-connector Creation date 16.12.2023 20:29:46 Subject to technical changes 1 Data sheet 15779.2 AQI/PRS/8 BK Technical data Connection data No. of poles 8 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:29:46 Subject to technical changes 2 Data sheet 15779.2 AQI/PRS/8 BK Media Creation date 16.12.2023 20:29:46 Subject to technical changes 3 Data sheet 15779.2 AQI/PRS/8 BK Accessories ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15136.2 PRS 2 4044211046194 1 ST Relay socket base PRS, for miniature power relay with 2 CO contacts, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15320.2 PRS 2 G 4044211047115 1 ST Pre-assembled relay module PRSXT, Screw connection, Consisting of: relay socket, holding clip and power contact relay with test button and status LED. 2 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16020.2 PRSUXT 2G/24V DC 4044211145255 10 ST Pre-assembled relay module PRSXT, Screw connection, Consisting of: relay socket, holding clip and power contact relay with test button and status LED. 2 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 16022.2 PRSUXT 2G/230V AC 4044211145279 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15166.2 PRSU 2/24V AC 4044211046453 10 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 4 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRSXT, Tension-spring connection, Consisting of: relay socket, holding clip and power contact relay with test button and status LED. 2 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 16024.2 PRSUXT 2Z/24V AC 4044211145293 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15233.2 PRSU 2G/24V DC 4044211046736 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15166.2 PRSU 2/24V AC 4044211046453 10 ST Pre-assembled relay module PRSXT, Screw connection, Consisting of: relay socket, holding clip and power contact relay with test button and status LED. 2 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16017.2 PRSUXT 2/24V DC 4044211145224 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15163.2 PRSU 1/12V DC 4044211046422 10 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 5 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Relay socket base PRS, for miniature power relay with 1 CO contact, Screw connection, Plug-in option for input/suppression modules, Mounting type: Mounting rail TS 35 Article number Article name GTIN (EAN) Packaging unit 15135.2 PRS 1 4044211046187 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15413.2 PRSU 2/115V AC 4044211080792 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 48 VAC Article number Article name GTIN (EAN) Packaging unit 15948.2 PRSU 2/48V AC 4044211141905 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 48 VAC Article number Article name GTIN (EAN) Packaging unit 15948.2 PRSU 2/48V AC 4044211141905 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base with multi-layer gold contact, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16125.2 PRSU 2/24V DC Au 4044211178192 1 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 6 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15165.2 PRSU 2/12V DC 4044211046446 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15172.2 PRSU 2/230V AC 4044211046491 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15385.2 PRSU 2G/24V AC 4044211080815 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15163.2 PRSU 1/12V DC 4044211046422 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15414.2 PRSU 2G/12V DC 4044211080808 1 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 7 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15415.2 PRSU 2G/48V DC 4044211080822 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15722.2 PRSU 2/110V DC 4044211138424 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15723.2 PRSU 2G/110V DC 4044211138431 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15163.2 PRSU 1/12V DC 4044211046422 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15164.2 PRSU 1/24V AC 4044211046439 1 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 8 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VAC Article number Article name GTIN (EAN) Packaging unit 15164.2 PRSU 1/24V AC 4044211046439 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15419.2 PRSU 1L/24V DC 4044211080761 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15418.2 PRSU 1/115V AC 4044211080754 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 48 VDC Article number Article name GTIN (EAN) Packaging unit 15415.2 PRSU 2G/48V DC 4044211080822 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15418.2 PRSU 1/115V AC 4044211080754 1 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 9 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15721.2 PRSU 1/110V DC 4044211138417 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16400.2 PRSU 1G/24 V DC-16A 4044211216511 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15418.2 PRSU 1/115V AC 4044211080754 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15418.2 PRSU 1/115V AC 4044211080754 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15170.2 PRSU 1/230V AC 4044211046477 10 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 10 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15419.2 PRSU 1L/24V DC 4044211080761 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 5 VDC Article number Article name GTIN (EAN) Packaging unit 16077.2 PRSU 1/5V DC 4044211171162 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15169.2 PRSU 1/24V DC 4044211046460 10 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 60 VDC Article number Article name GTIN (EAN) Packaging unit 15720.2 PRSU 1/60V DC 4044211138400 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 110 VDC Article number Article name GTIN (EAN) Packaging unit 15721.2 PRSU 1/110V DC 4044211138417 1 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 11 Data sheet 15779.2 AQI/PRS/8 BK ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16400.2 PRSU 1G/24 V DC-16A 4044211216511 1 ST Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 1 CO contact, Input voltage: 115 VAC Article number Article name GTIN (EAN) Packaging unit 15418.2 PRSU 1/115V AC 4044211080754 1 ST ##INVERSE##CONTA-ELECTRONICS Pre-assembled relay module PRS..., Screw connection, Consisting of: relay socket base, power contact relay, pluggable display/suppression module and holding clip, 2 CO contacts, Input voltage: 230 VAC Article number Article name GTIN (EAN) Packaging unit 15172.2 PRSU 2/230V AC 4044211046491 10 ST Creation date 16.12.2023 20:29:46 Subject to technical changes 12
15779.2 价格&库存
很抱歉,暂时无法提供与“15779.2”相匹配的价格&库存,您可以联系我们找货
