Data sheet
1578.2 RK 6-10/35 BG
Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10
mm², Width: 8 mm, Colour: Beige
Business data
Article number
1578.2
Article name
RK 6-10/35 BG
GTIN (EAN)
4044211047627
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
14.4 g
Weight per piece (including packaging)
15.21 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
1578.2
Product description
Creation date 15.12.2023 17:54:11
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
48 mm
Width
8 mm
Height TS 35/7.5
47 mm
Ratings
Rated voltage
800 V
Rated current
57 A
Rated cross-section
10 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
1.82 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
10 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
10 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
10 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
8
Stripping length
12 mm
Screw head
Slotted
Screw threading
M4
Tightening torque, min.
1.2 Nm
Tightening torque, max.
2 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A5
Number of cross-connection channels
1
End plate required
Number of test pick-off options
1
Environmental Product Compliance
REACH Conform
Yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
3
Data sheet
4
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
65 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
8
CSA stripping length
12 mm
CSA torque, max.
2 Nm
CSA torque, min.
1.2 Nm
CSA File Number
042110_0_000
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
65 A
CSAus wire cross-section AWG, min.
22
CSAus wire cross-section AWG, max.
8
CSAus stripping length
12 mm
CSAus File Number
042110_0_000
5
Data sheet
Approvals
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
800 V
KEMA rated current
57 A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
10 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
10 mm²
KEMA torque, min.
1.2 Nm
KEMA torque, max.
2 Nm
6
Data sheet
Media
7
Data sheet
Accessories
Cover
Cover, Length: 26.5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
2966.0
AD 1/8 WH
4044211056957
50 ST
Cover, Length: 32 mm, Width: 28 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2054.0
AD 4/32/B YE
4044211048600
50 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
2495.0
AD 4/32/B/E YE
4044211052966
50 ST
Cover, Length: 26.5 mm, Width: 8 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2954.0
AD 1/8/B YE
4044211056827
50 ST
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2001.2
AP 2,5-10 BG
4044211047979
50
End stop
8
Data sheet
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Cross-connector
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 30.3 mm,
Rated cross-section: 10 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2062.0
Q4
4044211048686
20 ST
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 14.1 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2060.0
Q2
4044211048662
50 ST
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 78.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2063.0
Q 10
4044211048693
10 ST
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 22.2 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2061.0
Q3
4044211048679
50 ST
Quick marking
9
Data sheet
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
9323.7
PMC SB 8/40 WH
4044211129231
400 ST
Insulation plate
Insulation plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2003.2
TRS 1 BG
4044211048068
100
Partition plate
Partition plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2002.2
TW 2,5-10 BG
4044211048044
50
Test adapters
Test adapter, Length: 37.3 mm, Pitch size: 8 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2817.0
TA 8/1/ST
4044211055431
10 ST
10
