1582.2
1582.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1582.2 数据手册
Data sheet 1582.2 RK 50-D BG Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated crosssection: 50 mm², Width: 20 mm, Colour: Beige Business data Article number 1582.2 Article name RK 50-D BG GTIN (EAN) 4044211047702 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 111.2 g Weight per piece (including packaging) 122.4 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 1582.2 Product description Feed-through terminal for direct mount Creation date 16.12.2023 20:32:44 Subject to technical changes 1 Data sheet 1582.2 RK 50-D BG Technical data Dimensions Length 109 mm Width 20 mm Height TS 35/7.5 65.75 mm Ratings Rated voltage 1000 V Rated current 150 A Rated cross-section 50 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 4.8 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 16 mm² Wire cross-section single core (rigid)/stranded, max. 50 mm² Wire cross-section stranded, min. 25 mm² Wire cross-section stranded, max. 50 mm² Wire cross-section stranded with wire-end ferrules, min. 25 mm² Wire cross-section stranded with wire-end ferrules, max. 50 mm² Wire cross-section AWG, min. 6 Wire cross-section AWG, max. 1/0 Stripping length 27 mm Screw head Inner hex (Allen) Screw threading M6 Tightening torque, min. 6 Nm Tightening torque, max. 8 Nm Creation date 16.12.2023 20:32:44 Subject to technical changes 2 Data sheet 1582.2 RK 50-D BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 B10 Banded wire up to 11,8 x 5,0 mm Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:32:44 No Subject to technical changes 3 Data sheet 1582.2 RK 50-D BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 150 A CSA wire cross-section AWG, min. 6 CSA wire cross-section AWG, max. 1/0 CSA stripping length 27 mm CSA File Number 042110_0_000 CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 150 A CSAus wire cross-section AWG, min. 6 CSAus wire cross-section AWG, max. 1/0 CSAus stripping length 27 mm CSAus File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 150 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 16 mm² KEMA wire cross-section single-core (rigid), max. 50 mm² KEMA wire cross-section stranded, min. 25 mm² KEMA wire cross-section stranded, max. 50 mm² Creation date 16.12.2023 20:32:44 Subject to technical changes 4 Data sheet 1582.2 RK 50-D BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 150 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 150 A UL wire cross-section single-core (rigid) AWG, min. 6 UL wire cross-section single-core (rigid) AWG, max. 1/0 UL wire cross-section stranded AWG, min. 6 UL wire cross-section stranded AWG, max. 1/0 UL torque 35 Lb In UL wire material Cu UL factory wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 50 mm² DNV GL rated current 150 A DNV GL rated voltage 600 V DNV GL test standard IEC 60947-7-1:2002 Creation date 16.12.2023 20:32:44 Subject to technical changes 5 Data sheet 1582.2 RK 50-D BG Media Creation date 16.12.2023 20:32:44 Subject to technical changes 6 Data sheet 1582.2 RK 50-D BG Accessories Cover Cover, Length: 50 mm, Width: 10 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2810.0 AD 1/50/B YE 4044211055387 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1121.2 MAG 50 BG 4044211080914 10 ST Allen key socket wrench Inner hex key with bare blade Article number Article name GTIN (EAN) Packaging unit 2818.0 ISKS 5 4044211055448 1 ST Quick marking Creation date 16.12.2023 20:32:44 Subject to technical changes 7 Data sheet 1582.2 RK 50-D BG Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST ##INVERSE##CONTA-CONNECT Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1121.2 MAG 50 BG 4044211080914 10 ST Creation date 16.12.2023 20:32:44 Subject to technical changes 8
1582.2 价格&库存
很抱歉,暂时无法提供与“1582.2”相匹配的价格&库存,您可以联系我们找货
  • 10+151.8853810+19.67186
