Data sheet
1584.2 RK 150-D BG
Feed-through terminal to mounting surface, Screw connection, Mounting type: Mounting surface, Rated crosssection: 150 mm², Width: 31 mm, Colour: Beige
Business data
Article number
1584.2
Article name
RK 150-D BG
GTIN (EAN)
4044211047740
Packaging unit
5
Quantity unit
PC
Weight per piece (not including packaging)
291.2 g
Weight per piece (including packaging)
312.4 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
1584.2
Product description
Feed-through terminal for direct mount
Creation date 16.12.2023 20:33:37
Subject to technical changes
1
Data sheet
1584.2 RK 150-D BG
Technical data
Dimensions
Length
109 mm
Width
31 mm
Height TS 35/7.5
99 mm
Ratings
Rated voltage
1000 V
Rated current
309 A
Rated cross-section
150 mm²
Rated impulse voltage
8 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
9.89 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
35 mm²
Wire cross-section single core (rigid)/stranded, max.
150 mm²
Wire cross-section stranded, min.
50 mm²
Wire cross-section stranded, max.
150 mm²
Wire cross-section stranded with wire-end ferrules,
min.
50 mm²
max.
150 mm²
Wire cross-section AWG, min.
2
Wire cross-section AWG, max.
300 Kcmil
Stripping length
38 mm
Screw head
Inner hex (Allen)
Screw threading
M 10
Tightening torque, min.
14 Nm
Tightening torque, max.
20 Nm
2
Data sheet
1584.2 RK 150-D BG
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Mounting face
Gauge plug acc. to EN 60 947-1
B14
Banded wire up to
20 x 8 mm
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
1584.2 RK 150-D BG
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
275 A
CSA wire cross-section AWG, min.
2
CSA wire cross-section AWG, max.
300 Kcmil
CSA stripping length
38 mm
CSA File Number
042110_0_000
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
275 A
CSAus wire cross-section AWG, min.
2
CSAus wire cross-section AWG, max.
300 Kcmil
CSAus stripping length
38 mm
CSAus File Number
042110_0_000
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
1000 V
KEMA rated current
309 A
KEMA rated impulse voltage
12 kV
KEMA wire cross-section single core (rigid), min.
35 mm²
KEMA wire cross-section single-core (rigid), max.
150 mm²
KEMA wire cross-section stranded, min.
35 mm²
KEMA wire cross-section stranded, max.
150 mm²
KEMA stripping length
38 mm
KEMA torque, min.
14 Nm
KEMA torque, max.
20 Nm
4
Data sheet
1584.2 RK 150-D BG
Approvals
UL Recognized
UL approval
UL 1059
UL Usegroup B: rated voltage
600 V
UL Usegroup B: rated current
275 A
UL Usegroup C: rated voltage
600 V
UL Usegroup C: rated current
275 A
UL wire cross-section single-core (rigid) AWG, min.
2
UL wire cross-section single-core (rigid) AWG, max.
350 Kcmil
UL wire cross-section stranded AWG, min.
2
UL wire cross-section stranded AWG, max.
350 Kcmil
UL torque
142 Lb In
UL wire material
Cu
UL factory wiring
1
UL File Number
E95701
UL Recognized
1
German Lloyd approval
DNV GL Certificate number
TAE000014T
DNV GL Location Classes
Temperature: B, Humidity: B, Vibration: A
DNV GL approval granted
1
DNV GL rated cross-section
150 mm²
DNV GL rated current
275 A
DNV GL rated voltage
600 V
DNV GL test standard
IEC 60947-7-1:2002
5
Data sheet
1584.2 RK 150-D BG
Media
6
Data sheet
1584.2 RK 150-D BG
Accessories
Cover
Cover, Length: 60 mm, Width: 21 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2806.0
AD 1/150/B YE
4044211055363
20 ST
Inlay profile
Inlay plate, Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2277.0
EP 150
4044211050849
10 ST
Measurement pick-off terminal
Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 10 mm², Width: 10 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1125.2
MAG 150/240 BG
4044211080921
10 ST
Allen key socket wrench
Inner hex key with bare blade
Article number
Article name
GTIN (EAN)
Packaging
unit
2773.0
ISKS 8
4044211055035
1 ST
Quick marking
7
Data sheet
1584.2 RK 150-D BG
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
##INVERSE##CONTA-CONNECT
Article number
Article name
GTIN (EAN)
Packaging
unit
1125.2
MAG 150/240 BG
4044211080921
10 ST
8
