15930.4
15930.4
    CONTA-CLIP
    INSULATED EXTERNAL CROSS CONNECT
15930.4 数据手册
Data sheet 15930.4 AQI/PRC/8 BK External cross-connector insulated for Plug-Relay-Compact (PRC 2), 8-pole, can be shortened, Voltage: 250 V, Current: 10 A RAL: 9005 Business data Article number 15930.4 Article name AQI/PRC/8 BK GTIN (EAN) 4044211137410 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 4.7 g Weight per piece (including packaging) 6.5 g Unit of weight G Customs number 85389099 Country of origin IT Prio-Article 15930.8 Product description Insulated external cross-connector Creation date 15.12.2023 16:26:48 Subject to technical changes 1 Data sheet 15930.4 AQI/PRC/8 BK Technical data Ratings Max. voltage 250 V Rated current 10 A Connection data No. of poles 8 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 16:26:48 No Subject to technical changes 2 Data sheet 15930.4 AQI/PRC/8 BK Media Creation date 15.12.2023 16:26:48 Subject to technical changes 3 Data sheet 15930.4 AQI/PRC/8 BK Accessories ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 2 CO contact, Input voltage: 6.12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15920.2 PRC 2 6-12-24V AC/DC 4044211137359 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 2 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15921.2 PRC 2 220...240V AC/DC 4044211137366 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 2 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15922.2 ZPRC 2 6-12-24V AC/DC 4044211137373 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 2 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15923.2 ZPRC 2 220...240V AC/DC 4044211137380 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 12 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15927.2 ZPRCU 2 12V AC/DC 4044211137458 10 ST Creation date 15.12.2023 16:26:48 Subject to technical changes 4 Data sheet 15930.4 AQI/PRC/8 BK ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 12 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15924.2 PRCU 2 12V AC/DC 4044211137427 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15925.2 PRCU 2 24V AC/DC 4044211137434 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15926.2 PRCU 2 240V AC/DC 4044211137441 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15928.2 ZPRCU 2 24V AC/DC 4044211137465 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15929.2 ZPRCU 2 240V AC/DC 4044211137472 10 ST Creation date 15.12.2023 16:26:48 Subject to technical changes 5 Data sheet 15930.4 AQI/PRC/8 BK ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with inrush power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16059.2 ZPRCU 1L/24V AC/DC 4044211149673 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRS... with inrush power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16058.2 PRCU 1L/24V AC/DC 4044211149666 10 ST ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 2 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15923.2 ZPRC 2 220...240V AC/DC 4044211137380 10 ST ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15928.2 ZPRCU 2 24V AC/DC 4044211137465 10 ST ##INVERSE##CONTA-ELECTRONICS Creation date 15.12.2023 16:26:48 Subject to technical changes 6 Data sheet 15930.4 AQI/PRC/8 BK Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15926.2 PRCU 2 240V AC/DC 4044211137441 10 ST ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRS... with power contact, Mounting type: Mounting rail TS 35, 2 CO contacts, Input voltage: 12 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15927.2 ZPRCU 2 12V AC/DC 4044211137458 10 ST Creation date 15.12.2023 16:26:48 Subject to technical changes 7
15930.4 价格&库存
很抱歉,暂时无法提供与“15930.4”相匹配的价格&库存,您可以联系我们找货
    • 1+214.578871+27.77909
