16004.2
16004.2
    CONTA-CLIP
    OVERVOLTAGE ARRESTER
16004.2 数据手册
Data sheet 16004.2 CP VH 40-2 Overvoltage arrester type 2, Consisting of base element and protective plug with high-performance varistor, remote signalling contact, Mounting type: Mounting rail TS 35, 2-channel, Rated voltage: 230 VAC Business data Article number 16004.2 Article name CP VH 40-2 GTIN (EAN) 4044211144517 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 199.8 g Weight per piece (including packaging) 215.9 g Unit of weight G Customs number 85354000 Country of origin CN Product description Overvoltage arresters Creation date 16.12.2023 03:04:29 Subject to technical changes 1 Data sheet 16004.2 CP VH 40-2 Technical data Dimensions Length 100.6 mm Width 36 mm Height 70 mm Installation dimensions acc. to DIN 43880 2 Te Ratings Rated voltage Un 230 / 400 - Rated discharge surge current In (8/20) µs 40 kA Rated frequency min. 50 Hz Rated frequency max. 60 Hz Short-circuit resistance Ip 25 kA Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 4 mm² Wire cross-section single-core (rigid), max. 25 mm² Wire cross-section stranded, min. 4 mm² Wire cross-section stranded, max. 25 mm² Wire cross-section stranded with wire-end ferrules, min. 25 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Output data Switching current, max. at 30 V DC 2A Switching current, max. at 250 V AC 0.5 A Remote signalling Potential-free CO contact Remote signalling: Wire cross-section single-core (rigid), max. 1,5 mm² Materials Insulation housing Thermoplastic Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 85 °C Creation date 16.12.2023 03:04:29 Subject to technical changes 2 Data sheet 16004.2 CP VH 40-2 Technical data Further technical data Protection class IP20 Response time tA
16004.2 价格&库存
很抱歉,暂时无法提供与“16004.2”相匹配的价格&库存,您可以联系我们找货
