16061.2
16061.2
    CONTA-CLIP
    GSM-ANTENNA
16061.2 数据手册
Data sheet 16061.2 GSM-ANTENNA-EXTERNAL-SMA-3M GSM UMTS antenna with omni-directional characteristic, SMA round plug, Connecting cable length: 3 m RAL: 9005 Business data Article number 16061.2 Article name GSM-ANTENNA-EXTERNAL-SMA-3M GTIN (EAN) 4044211145972 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 76 g Weight per piece (including packaging) 81 g Unit of weight G Customs number 85291069  Country of origin NL Product description GSM antenna Colour Black Creation date 14.12.2023 23:06:45 Subject to technical changes 1 Data sheet 16061.2 GSM-ANTENNA-EXTERNAL-SMA-3M Technical data Dimensions Length 45 mm Width 45 mm Height 39.5 mm Installation height 17 mm Drill hole diameter 17 mm Connection data Plug-in connector SMA-Male Antennengewinn max. 1 dBi GSM frequency 900, 1800, 2100 MHz Impedance 50 Ohm Materials Material Nylon 6 Working temperature, min. -40 °C Working temperature, max. 85 °C Further technical data Mounting type External, screw Cable length 3m Antenna shape Puck Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 23:06:45 Subject to technical changes 2 Data sheet 16061.2 GSM-ANTENNA-EXTERNAL-SMA-3M Media Creation date 14.12.2023 23:06:45 Subject to technical changes 3 Data sheet 16061.2 GSM-ANTENNA-EXTERNAL-SMA-3M Accessories ##INVERSE##CONTA-ELECTRONICS Compact reporting system for mobile networks to monitor analogue and digital values, and to remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16368.2 GSM-PRO2 4044211207731 1 ST Compact reporting system for mobile networks, for monitoring analogue and digital values ​and remotely switching relay outputs, incl. GSM positioning, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC Article number Article name GTIN (EAN) Packaging unit 16369.2 GSM-PRO2-GPS 4044211207748 1 ST Compact signaling system for mobile networks to monitor analog and digital values ​as well as remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16407.2 GSM-PRO2E 4044211219017 1 ST Compact reporting system for mobile networks to monitor analogue and digital values ​as well as remotely switch relay outputs, incl. GSM positioning, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC Article number Article name GTIN (EAN) Packaging unit 16408.2 GSM-PRO2E-GPS 4044211219024 1 ST Compact reporting system for mobile networks, for monitoring analogue and digital values ​and remotely switching relay outputs. Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC Article number Article name GTIN (EAN) Packaging unit 16099.2 GSM-PRO 4044211151560 1 ST Creation date 14.12.2023 23:06:45 Subject to technical changes 4
16061.2 价格&库存
很抱歉,暂时无法提供与“16061.2”相匹配的价格&库存,您可以联系我们找货
