16128.2
16128.2
    CONTA-CLIP
    RELAY TERMINAL
16128.2 数据手册
Data sheet 16128.2 PRCU 1/24V DC Au Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with multi-layer gold contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Business data Article number 16128.2 Article name PRCU 1/24V DC Au GTIN (EAN) 4044211178635 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 33.1 g Weight per piece (including packaging) 34.89 g Unit of weight G Customs number 85364900 Country of origin IT Product description Relay terminal Creation date 16.12.2023 06:04:51 Subject to technical changes 1 Data sheet 16128.2 PRCU 1/24V DC Au Technical data Dimensions Length 87.3 mm Width 6.2 mm Height TS 35 / 7.5 with BA 7.99 mm Ratings Rated voltage Un 24 VDC - Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Stripping length 10 mm Torque 0.5 Nm Input data Holding current 0,4 Un - Drop-out voltage 0,05 Un Operating range 16,8-36 VDC Power consumption 0,17 W Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 1500 VA Electrical lifespan (AC1) 60x10³ Mechanical lifespan 10x10⁶ Contact load, min. 50 mW Bounce time at close of the NO/NC contact 3/8 ms Materials Contact material AgNi + Au Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 70 °C Creation date 16.12.2023 06:04:51 Subject to technical changes 2 Data sheet 16128.2 PRCU 1/24V DC Au Technical data Further technical data Degree of protection IP20 Status display Insulation voltage coil/contact 4 kV Free-wheel diode Response/release time 12 / 5 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 10/5 g Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 06:04:51 Subject to technical changes 3 Data sheet 16128.2 PRCU 1/24V DC Au Approvals Standards and regulations CE compliant yes cUL approval CSA-C22.2 No. 14 UL approval UL 508 UL Recognized 1 cUL Recognized 1 Creation date 16.12.2023 06:04:51 Subject to technical changes 4 Data sheet 16128.2 PRCU 1/24V DC Au Media Creation date 16.12.2023 06:04:51 Subject to technical changes 5 Data sheet 16128.2 PRCU 1/24V DC Au Accessories Cross-connector External cross-connector insulated for Plug-Relay-Compact (PRC), 20-pole, can be shortened, Voltage: 250 V, Current: 36 A Article number Article name GTIN (EAN) Packaging unit 15545.8 AQI/PRC/20 YE 4044211118440 1 Quick marking Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9107.7 PMC BSTR 6/30 So WH 4044211099749 300 ST Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9106.7 PMC BSTR 6/30 WH 4044211099732 300 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 16.12.2023 06:04:51 Subject to technical changes 6 Data sheet 16128.2 PRCU 1/24V DC Au Relays Plug-in miniature power relay, With multi-layer gold contact, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15559.2 PRC 1/24V DC Au 4044211118396 10 ST Insert modules Insertion module, Suitable for relay socket base PRS, LED red status display, With freewheel diode Article number Article name GTIN (EAN) Packaging unit 15141.2 PRS LED(RD) 24V DC 4044211046231 1 ST Creation date 16.12.2023 06:04:51 Subject to technical changes 7
16128.2 价格&库存
很抱歉,暂时无法提供与“16128.2”相匹配的价格&库存,您可以联系我们找货
