16154.2
16154.2
    CONTA-CLIP
    CONTROL UNIT
16154.2 数据手册
Data sheet 16154.2 WE-CON-IP The WE-CON-IP module connects Modbus I/O modules to the Internet • 10BASE-T and 100BASE-TX • Auto MDI/MDIX • Integrated RS485 bias circuit • Integrated terminator • Voltage: 24VAC/DC Business data Article number 16154.2 Article name WE-CON-IP GTIN (EAN) 4044211207656 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 110 g Weight per piece (including packaging) 150 g Unit of weight G Customs number 85423190 Country of origin NL Product description Controller module Creation date 15.12.2023 04:28:36 Subject to technical changes 1 Data sheet 16154.2 WE-CON-IP Technical data BUS data Bus-Topologie / Kabellänge max. multidrop line / 500m Datenübertragungsrate / Bus-Teilnehmer max. 19k2 bps / 64 Bus protocol / interface Modbus RTU / RS485, halb duplex, nicht isoliert Dimensions Length 95 mm Width 71 mm Height 60 mm Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 6 mm Torque 0.4 Nm Input data Input type IEEE 802.3 10BASE-T and 802.3u 100BASE-TX compliant, auto MDI/MDI Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 04:28:36 Subject to technical changes 2 Data sheet 16154.2 WE-CON-IP Media Creation date 15.12.2023 04:28:36 Subject to technical changes 3 Data sheet 16154.2 WE-CON-IP Accessories Creation date 15.12.2023 04:28:36 Subject to technical changes 4
16154.2 价格&库存
很抱歉,暂时无法提供与“16154.2”相匹配的价格&库存,您可以联系我们找货
