16184.2
16184.2
    CONTA-CLIP
    DIRECT VOLTAGE SUPPLY
16184.2 数据手册
Data sheet 16184.2 PSPC 230/24-10A Primary clocked power supply, Push-In connection, Mounting type: Mounting rail TS 35, Input: 1-phase, Output: 24 VDC/10 A Business data Article number 16184.2 Article name PSPC 230/24-10A GTIN (EAN) 4044211184582 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 1022 g Weight per piece (including packaging) 1120 g Unit of weight G Customs number 85043180 Country of origin DE Product description DC power supply Creation date 16.12.2023 20:25:34 Subject to technical changes 1 Data sheet 16184.2 PSPC 230/24-10A Technical data Dimensions Length 55 mm Width 127 mm Height TS 35/7.5 161 mm Required minimum clearance (top/bottom) 50 mm Ratings Nominal input voltage 100 V Nominal input voltage AC max. 230 V Rated output voltage 24 ±1 % V Input current at rated load 2,74 A Input current at max. nominal input voltage 1,25 A Power loss for rated load 24,4 W Rated frequency min. 47 Hz Rated frequency max. 63 Hz Mains failure bridging time at rated load and min. nominal input voltage 15 ms Mains failure bridging time at rated load and max. nominal input voltage 17 ms Switch-on time at rated load and min. nominal input voltage 1,3 s Switch-on time at rated load and max. nominal input voltage 0,25 s Contamination degree 2 Connection data Connection principle Push-in connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 10 mm Creation date 16.12.2023 20:25:34 Subject to technical changes 2 Data sheet 16184.2 PSPC 230/24-10A Technical data Input data Input voltage derating -2,5 % Inrush current limit 21.5 V) Transient overvoltage protection Varistor Derating at K > 50 °C -3 % Power loss at no load 6,6 W Power loss, max. 31,3 W (100 VAC / 24 V / 10 A) Signal output DC OK Relay contact (Uout > 21.5 V) Creation date 16.12.2023 20:25:34 Subject to technical changes 3 Data sheet 16184.2 PSPC 230/24-10A Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:25:34 Subject to technical changes 4 Data sheet 16184.2 PSPC 230/24-10A Approvals Standards and regulations CE compliant yes EMC EN 61204-3 Safety EN 61558-2-16, EN 60950-1 Protective low voltage (SELV/PELV) IEC 60364-4-41 (DIN VDE 0100-410) Creation date 16.12.2023 20:25:34 Subject to technical changes 5 Data sheet 16184.2 PSPC 230/24-10A Media Creation date 16.12.2023 20:25:34 Subject to technical changes 6 Data sheet 16184.2 PSPC 230/24-10A Accessories Creation date 16.12.2023 20:25:34 Subject to technical changes 7
16184.2 价格&库存
很抱歉,暂时无法提供与“16184.2”相匹配的价格&库存,您可以联系我们找货
