16369.2
16369.2
    CONTA-CLIP
    CONTROL UNIT
16369.2 数据手册
Data sheet 16369.2 GSM-PRO2-GPS Compact reporting system for mobile networks, for monitoring analogue and digital values ​and remotely switching relay outputs, incl. GSM positioning, Mounting type: Mounting rail TS 35, Supply voltage range: 10  30 VDC RAL: 9018 Business data Article number 16369.2 Article name GSM-PRO2-GPS GTIN (EAN) 4044211207748 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 100 g Weight per piece (including packaging) 137 g Unit of weight G Customs number 85176990 Country of origin NL Product description Controller module Colour Light grey Creation date 15.12.2023 21:52:39 Subject to technical changes 1 Data sheet 16369.2 GSM-PRO2-GPS Technical data Dimensions Length 95 mm Width 36 mm Height 65 mm Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Stripping length 6 mm Torque 0.4 Nm Output data Number of outputs 1 Switching voltage / switching voltage max. 250 / 250 VAC Continuous current max. / Inrush current max. 5/5A Switching capacity, max. 1200 VA Switching frequency, max. 6/min kHz Electrical lifespan (AC1) 1,5x10⁵ Mechanical lifespan 15x10⁶ Relay contact 1CO Input data Number of channels 2 Input signal U/I, max. 30 V / - Input resistance U/I 80K / 500 Ohm Resolution U (0 ... 10 Vdc) 20mV / ±(20mV+0,3%) Resolution I (0 ... 20 mA) 40 µA / ± (40 µ + 0,3%) Pulse length, min. 500 ms Threshold digital inputs Low 4V Counter input (pull-down) 1000 pulses/s, max. pull-down res. 24 kOhm Materials Contact material AgNi 90/10 Working temperature, min. -20 °C Working temperature, max. 50 °C Relative humidity, max. 80 (non-condensing) % Creation date 15.12.2023 21:52:39 Subject to technical changes 2 Data sheet 16369.2 GSM-PRO2-GPS Technical data GSM data SIM card Nano SIM 2G Quad-band GSM bands: 850, 900, 1800 and 1900 MHz 3G Five-band UMTS (WCDMA/FDD) bands: 800, 850, 900, 1800, 1900 and 2100 MHz Antenna GSM 50 ohm, SMA plug GPS data GPS frequency 1575-1587 MHz Time to first fix (@ -140 dBm ) Hot < 2s, warm < 35s, cold < 46s Antenna GPS 50 ohm, SMA plug Voltage active antenna 3 V @ RF plug Further technical data Power supply 10-30 VDC - Current consumption 275 @ 24 VDC mA Protection class IP20 Storage temperature, min. -20 °C Storage temperature, max. 70 °C Mounting Mounting rail TS35 / direct mount Backup power Internal maintenance-free supercap capacitor Electromagnetic properties Directive 2014/30/EC in compliance with EN 55011 and EN 61326-1 Frequency spectrum RED 2014/53/EC in compliance with ETSI EN 301-511 V9.0.2 Hz Number of expansion modules, max. 15 BUS data Bus protocol / interface Modbus RTU / RS485, half-duplex, non-insulated Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 21:52:39 Subject to technical changes 3 Data sheet 16369.2 GSM-PRO2-GPS Approvals Standards and regulations Standards / specifications Creation date 15.12.2023 21:52:39 Low-Voltage Directive (LVD) 2014/35/EC, in compliance with EN 50178. EMC Directive 2014/30/EC, in compliance with EN 61326-1 Subject to technical changes 4 Data sheet 16369.2 GSM-PRO2-GPS Media Creation date 15.12.2023 21:52:39 Subject to technical changes 5 Data sheet 16369.2 GSM-PRO2-GPS Accessories GSM-PRO I/O-Modules GSM-PRO I/O digital input module, 10 digital inputs 24V with LED display, Mounting type: Mounting rail TS 35, Supply voltage range: 20 V - 28 VDC Article number Article name GTIN (EAN) Packaging unit 16375.2 GSM-PRO-10DI 4044211207755 1 ST GSM-PRO I/O analogue output module, 4 analogue outputs 0 - 10V, Mounting type: Mounting rail TS 35, Supply voltage range: 20 V - 28 VDC Article number Article name GTIN (EAN) Packaging unit 16376.2 GSM-PRO-4AO 4044211207762 1 ST GSM-PRO I/O analogue input module, 8 analogue inputs 0 - 10 V, 0 (4) - 0 mA, NTC, RTD (PT1000 / NI1000), Mounting type: Mounting rail TS 35, Supply voltage range: 20  28 VDC Article number Article name GTIN (EAN) Packaging unit 16377.2 GSM-PRO-8AI 4044211207779 1 ST Signal converter for converting voltage/current signals to an analogue standard signal, Screw connection, Mounting type: Mounting rail TS 35, Supply voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16374.2 CAE/I-I/020-010 4044211207502 1 ST Antennas GSM UMTS antenna with omni-directional characteristic, SMA round plug, Connecting cable length: 3 m Article number Article name GTIN (EAN) Packaging unit 16061.2 GSM-ANTENNA-EXTERNAL-SMA-3M 4044211145972 1 ST Creation date 15.12.2023 21:52:39 Subject to technical changes 6 Data sheet 16369.2 GSM-PRO2-GPS Antennas GSM UMTS antenna with omni-directional characteristic, SMA round plug, Connecting cable length: 5 m Article number Article name GTIN (EAN) Packaging unit 16172.2 GSM-ANTENNA-EXTERNAL-SMA-5m 4044211187002 1 ST GSM omni-directional antenna, 90° with SMA round connector Article number Article name GTIN (EAN) Packaging unit 16379.2 GSM-ANTENNA-90° 4044211207793 1 ST Combined cellular/GPS antenna with omni-directional, SMA round connector (GSM/UMTS) and R-SMA round connector (GPS), connection cable length 3 m Article number 16381.2 Article name GSM-ANTENNA-EXTERNAL-GSM+GPS-SMA3M GTIN (EAN) Packaging unit 4044211207816 1 ST GSM UMTS antenna with omni-directional characteristic, SMA round plug, Connecting cable length: 10 m Article number Article name GTIN (EAN) Packaging unit 16173.2 GSM-ANTENNA-EXTERNAL-SMA-10M 4044211187019 1 ST Connection cables USB 2.0 connection cable [1 USB 2.0 plug A - 1 USB 2.0 plug Micro-B] Cable length: 1.5 m, gold-plated plug contacts, colour: black Article number Article name GTIN (EAN) Packaging unit 16382.2 GSM-USB-MICRO-cable 4044211207823 1 ST Creation date 15.12.2023 21:52:39 Subject to technical changes 7
16369.2 价格&库存
很抱歉,暂时无法提供与“16369.2”相匹配的价格&库存,您可以联系我们找货
