Data sheet
16376.2 GSM-PRO-4AO
GSM-PRO I/O analogue output module, 4 analogue outputs 0 - 10V, Mounting type: Mounting rail TS 35,
Supply voltage range: 20 V - 28 VDC
Business data
Article number
16376.2
Article name
GSM-PRO-4AO
GTIN (EAN)
4044211207762
Packaging unit
1
Quantity unit
PC
Weight per piece (not including packaging)
64 g
Weight per piece (including packaging)
66 g
Unit of weight
G
Customs number
85176990
Country of origin
NL
Product description
Controller module
Creation date 16.12.2023 14:18:26
Subject to technical changes
1
Data sheet
16376.2 GSM-PRO-4AO
Technical data
Dimensions
Length
95 mm
Width
36 mm
Height
60 mm
Connection data
Connection principle
Screw connection
Wire cross-section single core (rigid), min.
0.2 mm²
Wire cross-section single-core (rigid), max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Stripping length
6 mm
Torque
0.4 Nm
Output data
Number of outputs
4
Output type
Analogue
Output signal U/I
0-10 VDC / -
Load resistance U
>1000 Ohm Ohm
Input data
Resolution U (0 ... 10 Vdc)
10bit / ± (30mV + 0,5% of measured value)
Materials
Working temperature, min.
-20 °C
Working temperature, max.
60 °C
Temperature coefficient
很抱歉,暂时无法提供与“16376.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2887.819641+374.02403
