16382.2
16382.2
    CONTA-CLIP
    INTERFACE CABLE
16382.2 数据手册
Data sheet 16382.2 GSM-USB-MICRO-cable USB 2.0 connection cable [1 USB 2.0 plug A - 1 USB 2.0 plug Micro-B] Cable length: 1.5 m, gold-plated plug contacts, colour: black RAL: 9005 Business data Article number 16382.2 Article name GSM-USB-MICRO-cable GTIN (EAN) 4044211207823 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 24 g Weight per piece (including packaging) 27 g Unit of weight G Customs number 85444290 Country of origin CN Product description Interface cable Colour Black Creation date 16.12.2023 20:29:59 Subject to technical changes 1 Data sheet 16382.2 GSM-USB-MICRO-cable Technical data Connection data Plug-in connector Micro USB Further technical data Cable length 1,5 m Connector type Micro USB Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:29:59 Subject to technical changes 2 Data sheet 16382.2 GSM-USB-MICRO-cable Media Creation date 16.12.2023 20:29:59 Subject to technical changes 3 Data sheet 16382.2 GSM-USB-MICRO-cable Accessories ##INVERSE##CONTA-ELECTRONICS Compact reporting system for mobile networks to monitor analogue and digital values, and to remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16368.2 GSM-PRO2 4044211207731 1 ST Compact reporting system for mobile networks, for monitoring analogue and digital values ​and remotely switching relay outputs, incl. GSM positioning, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC Article number Article name GTIN (EAN) Packaging unit 16369.2 GSM-PRO2-GPS 4044211207748 1 ST Compact reporting system for mobile networks (up to and including 4G) to monitor analogue and digital values, and to remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16454.2 GSM-PRO2-4G-EU 4044211222505 1 ST Compact reporting system for mobile networks (up to and including 4G) to monitor analogue and digital values, and to remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16454.2 GSM-PRO2-4G-EU 4044211222505 1 ST Compact reporting system for mobile networks to monitor analogue and digital values ​as well as remotely switch relay outputs, incl. GSM positioning, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC Article number Article name GTIN (EAN) Packaging unit 16408.2 GSM-PRO2E-GPS 4044211219024 1 ST Creation date 16.12.2023 20:29:59 Subject to technical changes 4 Data sheet 16382.2 GSM-USB-MICRO-cable ##INVERSE##CONTA-ELECTRONICS Compact signaling system for mobile networks (up to and including 4G) to monitor analog and digital values ​as well as remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16457.2 GSM-PRO2E-4G-US 4044211222536 1 ST Compact signaling system for mobile networks (up to and including 4G) to monitor analog and digital values ​as well as remotely switch relay outputs, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC. Article number Article name GTIN (EAN) Packaging unit 16457.2 GSM-PRO2E-4G-US 4044211222536 1 ST Compact reporting system for mobile networks to monitor analogue and digital values ​as well as remotely switch relay outputs, incl. GSM positioning, Mounting type: Mounting rail TS 35, Supply voltage range: 10 - 30 VDC Article number Article name GTIN (EAN) Packaging unit 16408.2 GSM-PRO2E-GPS 4044211219024 1 ST Auto Send SMS Module, 230V AC. The module sends an SMS after power is connected. The telephone numbers are fully configurable using your Windows PC via a USB port. The GSM-TMM is therefore ideal as fault detector. Article number Article name GTIN (EAN) Packaging unit 16511.2 GSM-TMM-230VAC 4044211236366 1 ST Auto Send SMS Module, 10…30V dc, 24V ac. The module sends an SMS after power is connected. The telephone numbers are fully configurable using your Windows PC via a USB port. The GSM-TMM is therefore ideal as fault detector. Article number Article name GTIN (EAN) Packaging unit 16489.2 GSM-TMM-12VDC/24VUC 4044211236373 1 ST Creation date 16.12.2023 20:29:59 Subject to technical changes 5
16382.2 价格&库存
很抱歉,暂时无法提供与“16382.2”相匹配的价格&库存,您可以联系我们找货
