17001.2
17001.2
    CONTA-CLIP
    板对板连接器
17001.2 数据手册
Data sheet 17001.2 HSK 35/M6 B BG High-power stud terminal, Stud connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Business data Article number 17001.2 Article name HSK 35/M6 B BG GTIN (EAN) 4044211131463 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 25.3 g Weight per piece (including packaging) 31.23 g Unit of weight G Customs number 85369010 Country of origin DE Product description High-power stud terminal Colour Beige Creation date 16.12.2023 20:31:20 Subject to technical changes 1 Data sheet 17001.2 HSK 35/M6 B BG Technical data Dimensions Length 67 mm Length with TW/ADH 67 mm Width 16 mm Height TS 35/7.5 55.5 mm Height TS 35/7.5 with TW/ADH 58 mm Ratings Rated voltage 1000 V Rated current 125 A Rated cross-section 35 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 4W Connection data Connection principle Stud connection Connection position Top Connections 1 Number of terminals per level 1 Number of levels 1 Wire cross-section AWG, min. 14 Wire cross-section AWG, max. 2 Bolt head Hexagon Bolt thread M6 Tightening torque, min. 3 Nm Tightening torque, max. 6 Nm Contact wire range ≤ 35 mm² Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 20:31:20 Subject to technical changes 2 Data sheet 17001.2 HSK 35/M6 B BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Number of cross-connection channels 1 DIN 46234 / 1 cable lug per side, min. 2.5 mm² DIN 46234 / 1 cable lug per side, max. 35 mm² DIN 46234 / 2 cable lugs per side, min. 2.5 mm² DIN 46234 / 2 cable lugs per side, max. 35 mm² DIN 46235: 1 cable lug per side, max. 35 mm² DIN 46235: 1 cable lug per side, min. 6 mm² DIN 46235: 2 cable lugs per side, min. 6 mm² DIN 46235: 2 cable lugs per side, max. 35 mm² Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:31:20 Subject to technical changes 3 Data sheet 17001.2 HSK 35/M6 B BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 1000 V CSA Usegroup C: rated current 115 A CSA Usegroup D: rated voltage 1000 V CSA Usegroup D: rated current 115 A CSA wire cross-section AWG, max. 4 CSA torque, max. 12.4 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 1000 V CSAus Usegroup C: rated current 115 A CSAus Usegroup D: rated voltage 1000 V CSAus Usegroup D: rated current 115 A CSAus wire cross-section AWG, max. 4 CSAus torque, max. 12.4 Nm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup E: rated voltage 1000 V cUL Usegroup E: rated current 115 A cUL wire cross-section AWG, max. 2 cUL torque, max. 12.4 Nm cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 20:31:20 Subject to technical changes 4 Data sheet 17001.2 HSK 35/M6 B BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 125 A KEMA rated impulse voltage 8 kV KEMA wire cross-section (DIN 46234), min. 2.5 mm² KEMA wire cross-section (DIN 46234), max. 35 mm² KEMA wire cross-section (DIN 46235), min. 6 mm² KEMA wire cross-section (DIN 46235), max. 35 mm² UL Recognized UL approval UL 1059 UL Usegroup E: rated voltage 1000 V UL Usegroup E: rated current 115 A UL wire cross-section AWG, max. 2 UL torque, max. 109.7 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:31:20 Subject to technical changes 5 Data sheet 17001.2 HSK 35/M6 B BG Media Creation date 16.12.2023 20:31:20 Subject to technical changes 6 Data sheet 17001.2 HSK 35/M6 B BG Accessories Protective hood Cover profile, Length: 70 mm, Width: 16 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17020.8 AD 35 YE 4044211131654 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 32 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17010.0 QS 2/35 4044211131555 10 ST Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 37 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17028.2 QS 2 HSK 35/M6 - M8 4044211139735 1 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 82 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17029.2 QS 3 HSK 35/M6 - M10/2 4044211139742 1 ST Creation date 16.12.2023 20:31:20 Subject to technical changes 7 Data sheet 17001.2 HSK 35/M6 B BG Cross-connector Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 50 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17011.0 QS 3/35 4044211131562 10 ST Partition plate Partition plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17018.2 TW 16-120 BG 4044211131630 20 ST Creation date 16.12.2023 20:31:20 Subject to technical changes 8
17001.2 价格&库存
很抱歉,暂时无法提供与“17001.2”相匹配的价格&库存,您可以联系我们找货
  • 10+181.6475110+23.52659
