17000.2
    CONTA-CLIP
    HIGH-POWER STUD TERMINAL
17000.2 数据手册
Data sheet 17000.2 HSK 16/M5 B BG High-power stud terminal, Stud connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 13 mm, Colour: Beige Business data Article number 17000.2 Article name HSK 16/M5 B BG GTIN (EAN) 4044211131333 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 18.5 g Weight per piece (including packaging) 22.12 g Unit of weight G Customs number 85369010 Country of origin DE Product description High-power stud terminal Colour Beige Creation date 16.12.2023 20:11:10 Subject to technical changes 1 Data sheet 17000.2 HSK 16/M5 B BG Technical data Dimensions Length 67 mm Length with TW/ADH 67 mm Width 13 mm Height TS 35/7.5 55.5 mm Height TS 35/7.5 with TW/ADH 58 mm Ratings Rated voltage 1000 V Rated current 76 A Rated cross-section 16 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.43 W Connection data Connection principle Stud connection Connection position Top Connections 1 Number of terminals per level 1 Number of levels 1 Wire cross-section AWG, min. 10 Wire cross-section AWG, max. 1/0 Bolt head Hexagon Bolt thread M5 Tightening torque, min. 2 Nm Tightening torque, max. 4 Nm Contact wire range ≤ 16 mm² Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 20:11:10 Subject to technical changes 2 Data sheet 17000.2 HSK 16/M5 B BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Number of cross-connection channels 1 DIN 46234 / 1 cable lug per side, min. 0.1 mm² DIN 46234 / 1 cable lug per side, max. 16 mm² DIN 46234 / 2 cable lugs per side, min. 0.1 mm² DIN 46234 / 2 cable lugs per side, max. 16 mm² DIN 46235: 1 cable lug per side, max. 10 mm² DIN 46235: 1 cable lug per side, min. 6 mm² DIN 46235: 2 cable lugs per side, min. 6 mm² DIN 46235: 2 cable lugs per side, max. 10 mm² Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:11:10 Subject to technical changes 3 Data sheet 17000.2 HSK 16/M5 B BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 1000 V CSA Usegroup C: rated current 60 A CSA Usegroup D: rated voltage 1000 V CSA Usegroup D: rated current 60 A CSA wire cross-section AWG, max. 8 CSA torque, max. 8.5 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 1000 V CSAus Usegroup C: rated current 60 A CSAus Usegroup D: rated voltage 1000 V CSAus Usegroup D: rated current 60 A CSAus wire cross-section AWG, max. 8 CSAus torque, max. 8.5 Nm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup E: rated voltage 1000 V cUL Usegroup E: rated current 60 A cUL wire cross-section AWG, max. 6 cUL torque, max. 8.5 Nm cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 20:11:10 Subject to technical changes 4 Data sheet 17000.2 HSK 16/M5 B BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 76 A KEMA rated impulse voltage 8 kV KEMA wire cross-section (DIN 46234), min. 0.1 mm² KEMA wire cross-section (DIN 46234), max. 16 mm² KEMA wire cross-section (DIN 46235), min. 0.1 mm² KEMA wire cross-section (DIN 46235), max. 10 mm² UL Recognized UL approval UL 1059 UL Usegroup E: rated voltage 1000 V UL Usegroup E: rated current 60 A UL wire cross-section AWG, max. 6 UL torque, max. 75.2 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:11:10 Subject to technical changes 5 Data sheet 17000.2 HSK 16/M5 B BG Media Creation date 16.12.2023 20:11:10 Subject to technical changes 6 Data sheet 17000.2 HSK 16/M5 B BG Accessories Protective hood Cover profile, Length: 52 mm, Width: 13 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17019.8 AD 16 YE 4044211131647 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 27 mm, Rated cross-section: 16 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17008.0 QS 2/16 4044211131531 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 42 mm, Rated cross-section: 16 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17009.0 QS 3/16 4044211131548 10 ST Creation date 16.12.2023 20:11:10 Subject to technical changes 7 Data sheet 17000.2 HSK 16/M5 B BG Partition plate Partition plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17018.2 TW 16-120 BG 4044211131630 20 ST Creation date 16.12.2023 20:11:10 Subject to technical changes 8
17000.2
物料型号:17000.2 HSK 16/M5 B BG
器件简介:这是一种高功率的螺柱端子,螺柱连接方式,适用于安装轨道TS 35/7.5,额定截面积16 mm²,宽度13 mm,颜色为米色。
引脚分配:该端子有一个连接位,位于顶部,每层有一个端子,共有一层。
参数特性: - 长度:67 mm - 宽度:13 mm - 高度(TS 35/7.5):55.5 mm - 额定电流:76A - 额定截面积:16 mm² - 额定脉冲电压:8kV - 污染等级:3 - 最大功率耗散(额定条件):2.43W
功能详解:该端子符合多种标准和认证,如EAC、CSA、cUL、KEMA KEUR和UL,适用于不同的电压和电流等级。
应用信息:端子适用于高功率连接,具有多种认证,适用于多种电气安装。
封装信息:绝缘外壳材料为聚酰胺6.6,阻燃等级为UL 94 V-0,工作温度范围从-40°C至120°C。
17000.2 价格&库存
很抱歉,暂时无法提供与“17000.2”相匹配的价格&库存,您可以联系我们找货
