17011.0
17011.0
    CONTA-CLIP
    CROSS CONNECTOR
17011.0 数据手册
Data sheet 17011.0 QS 3/35 Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 50 mm, Rated cross-section: 35 mm², Colour: natural Business data Article number 17011.0 Article name QS 3/35 GTIN (EAN) 4044211131562 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 23 g Weight per piece (including packaging) 23.2 g Unit of weight G Customs number 85389099 Country of origin DE Product description Cross-connector Colour Natural Creation date 16.12.2023 02:59:53 Subject to technical changes 1 Data sheet 17011.0 QS 3/35 Technical data Dimensions Length 15 mm Width 50 mm Height 4 mm Hole diameter 6.6 mm Hole spacing (mid-point to mid-point) 18 mm Pitch size 18 mm Connection data No. of poles 3 Materials Material Copper Surface Tin-plated Further technical data Mounting type Screwable Number of bridged terminals 3 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 02:59:53 Subject to technical changes 2 Data sheet 17011.0 QS 3/35 Media Creation date 16.12.2023 02:59:53 Subject to technical changes 3 Data sheet 17011.0 QS 3/35 Accessories ##INVERSE##CONTA-CONNECT High-power stud terminal, Stud connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17001.2 HSK 35/M6 B BG 4044211131463 10 ST High-power stud terminal, Stud connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17005.2 HSK 35/M6 B/B BG 4044211131500 10 ST Creation date 16.12.2023 02:59:53 Subject to technical changes 4
17011.0 价格&库存
很抱歉,暂时无法提供与“17011.0”相匹配的价格&库存,您可以联系我们找货
  • 1+130.557451+16.94398
