17014.0
17014.0
    CONTA-CLIP
    CROSS CONNECTOR
17014.0 数据手册
Data sheet 17014.0 QS 2/120/10 Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 62 mm, Rated cross-section: 120 mm², Colour: natural Business data Article number 17014.0 Article name QS 2/120/10 GTIN (EAN) 4044211131609 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 49 g Weight per piece (including packaging) 49.4 g Unit of weight G Customs number 85389099 Country of origin DE Product description Cross-connector Colour Natural Creation date 15.12.2023 15:49:03 Subject to technical changes 1 Data sheet 17014.0 QS 2/120/10 Technical data Dimensions Length 25 mm Width 62 mm Height 4 mm Hole diameter 10.6 mm Hole spacing (mid-point to mid-point) 34 mm Pitch size 34 mm Connection data No. of poles 2 Materials Material Copper Surface Tin-plated Further technical data Mounting type Screwable Number of bridged terminals 2 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 15:49:03 Subject to technical changes 2 Data sheet 17014.0 QS 2/120/10 Media Creation date 15.12.2023 15:49:03 Subject to technical changes 3 Data sheet 17014.0 QS 2/120/10 Accessories ##INVERSE##CONTA-CONNECT High-power stud terminal, Stud connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 120 mm², Width: 32 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17003.2 HSK 120/M10 B BG 4044211131487 10 ST High-power stud terminal, Stud connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 120 mm², Width: 32 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17007.2 HSK 120/M10 B/B BG 4044211131524 10 ST Creation date 15.12.2023 15:49:03 Subject to technical changes 4
17014.0 价格&库存
很抱歉,暂时无法提供与“17014.0”相匹配的价格&库存,您可以联系我们找货
