1708.2
1708.2
    CONTA-CLIP
    EX THREE-LEVEL TERMINAL CERTIFIE
1708.2 数据手册
Data sheet 1708.2 ZIKD 2,5 Ex BG Ex triple-level terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Business data Article number 1708.2 Article name ZIKD 2,5 Ex BG GTIN (EAN) 4044211107932 Explosion-proof version (EEx e) yes Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 21.8 g Weight per piece (including packaging) 23.75 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1708.2 Product description Ex triple-level terminal ATEX-certified Creation date 16.12.2023 20:33:25 Subject to technical changes 1 Data sheet 1708.2 ZIKD 2,5 Ex BG Technical data Dimensions Length 116.2 mm Width 5.1 mm Height TS 35/7.5 68 mm Ratings Rated voltage 500 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.3 W Connection data Connection principle Tension-spring connection Connection position Top Connections 3x2 Number of terminals per level 2 Number of levels 3 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 12 Stripping length 10 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 20:33:25 Subject to technical changes 2 Data sheet 1708.2 ZIKD 2,5 Ex BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 3 End plate required Number of test pick-off options 6 Can be cross-connected Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:33:25 No Subject to technical changes 3 Data sheet 1708.2 ZIKD 2,5 Ex BG Approvals Standards and regulations ATEX certification number TÜV ATEX 7093 U EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 15 A CSA wire cross-section AWG, min. 20 CSA wire cross-section AWG, max. 12 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 15 A CSAus wire cross-section AWG, min. 20 CSAus wire cross-section AWG, max. 12 CSAus stripping length 10 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 15 A cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 12 cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 20:33:25 Subject to technical changes 4 Data sheet 1708.2 ZIKD 2,5 Ex BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 24 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 15 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 12 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:33:25 Subject to technical changes 5 Data sheet 1708.2 ZIKD 2,5 Ex BG Approvals DNV GL Approval DNV GL Certificate number TAE00000Y7 DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 2.5 mm² DNV GL rated current 24 A DNV GL rated voltage 500 V DNV GL test standard IEC 60947-7-1:2009 DNV GL wire cross-section single-core (rigid), max. 4 mm² DNV GL wire cross-section stranded, max. 2.5 mm² Creation date 16.12.2023 20:33:25 Subject to technical changes 6 Data sheet 1708.2 ZIKD 2,5 Ex BG Media Creation date 16.12.2023 20:33:25 Subject to technical changes 7 Data sheet 1708.2 ZIKD 2,5 Ex BG Accessories Reducing sleeves Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3751.6 ZRH 2,5/0,25-0,5 GR 4044211060602 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 3750.7 ZRH 2,5/0,13-0,2 WH 4044211060596 1000 ST Reducing sleeve, Width: 51 mm, Pitch size: 5.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3752.4 ZRH 2,5/0,75-1,0 BK 4044211060619 1000 ST Creation date 16.12.2023 20:33:25 Subject to technical changes 8
1708.2 价格&库存
很抱歉,暂时无法提供与“1708.2”相匹配的价格&库存,您可以联系我们找货
  • 50+49.2043050+6.39423
