17104.7
17104.7
    CONTA-CLIP
    FEED-THROUGH TERMINAL
17104.7 数据手册
Data sheet 17104.7 SRK 4/2A WH Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: White RAL: 9010 Business data Article number 17104.7 Article name SRK 4/2A WH GTIN (EAN) 4044211170257 Explosion-proof version (EEx e) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 8.5 g Weight per piece (including packaging) 9.08 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 17104.2 Product description Feed-through terminal Creation date 17.12.2023 18:04:23 Subject to technical changes 1 Data sheet 17104.7 SRK 4/2A WH Technical data Dimensions Length 48 mm Width 6 mm Height TS 35/7.5 47 mm Ratings Rated voltage 1000 V Rated current 32 A Current load, max. 41 A Rated cross-section 4 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Creation date 17.12.2023 18:04:23 Subject to technical changes 2 Data sheet 17104.7 SRK 4/2A WH Technical data Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 4 mm² Wire cross-section AWG, min. 26 Wire cross-section AWG, max. 10 Stripping length 10 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Wire cross-section single-core (rigid) / stranded, AWGmax. 10 Wire cross-section single-core (rigid) / stranded, AWGmin. 26 Wire cross-section stranded, AWG max. 10 Wire cross-section stranded, AWG min. 26 Wire cross-section stranded with wire-end ferrules, AWG max. 12 Wire cross-section stranded with wire-end ferrules, AWG min. 26 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 18:04:23 Subject to technical changes 3 Data sheet 17104.7 SRK 4/2A WH Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 2 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 18:04:23 No Subject to technical changes 4 Data sheet 17104.7 SRK 4/2A WH Approvals Standards and regulations ATEX certification number DEKRA 12ATEX0039 U EAC approval TR ZU 004/2011 EAC approval granted yes IECEx certification number IECEx DEK 12.0006U CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 35 A CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 10 CSA torque, max. 1 Nm CSA torque, min. 0.5 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 35 A CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 10 CSAus torque, min. 0.5 Nm CSAus torque, max. 1 Nm Creation date 17.12.2023 18:04:23 Subject to technical changes 5 Data sheet 17104.7 SRK 4/2A WH Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 35 A cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 35 A cUL wire cross-section single-core (rigid) AWG, min. 26 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 26 cUL wire cross-section stranded AWG, max. 10 cUL torque, min. 0.5 Nm cUL torque, max. 1 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 41 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.5 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.5 mm² KEMA wire cross-section stranded, max. 6 mm² KEMA torque, min. 0.5 Nm KEMA torque, max. 1 Nm Creation date 17.12.2023 18:04:23 Subject to technical changes 6 Data sheet 17104.7 SRK 4/2A WH Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 35 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 35 A UL wire cross-section single-core (rigid) AWG, min. 26 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 26 UL wire cross-section stranded AWG, max. 10 UL torque, min. 4.4 Lb In. UL torque, max. 8.8 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE00002JG DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 4 mm² DNV GL rated current 41 A DNV GL rated impulse voltage 8 kV DNV GL rated voltage 1000 V DNV GL test standard IEC 60947-7-1:2009 Creation date 17.12.2023 18:04:23 Subject to technical changes 7 Data sheet 17104.7 SRK 4/2A WH Media Creation date 17.12.2023 18:04:23 Subject to technical changes 8 Data sheet 17104.7 SRK 4/2A WH Accessories Cover Cover, Width: 6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17296.8 SAD 1/6/B YE 4044211205447 50 ST Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 2.5 mm², Width: 5.9 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17120.2 SMAG 4/2,5 BG 4044211172107 10 ST End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2001.2 AP 2,5-10 BG 4044211047979 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulation cap for cross-connector Creation date 17.12.2023 18:04:23 Subject to technical changes 9 Data sheet 17104.7 SRK 4/2A WH Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 Insulated cross-connector Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 17.4 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17212.8 SQI 4/3 YE 4044211148652 50 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 11.3 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17211.8 SQI 4/2 YE 4044211148645 50 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 47.9 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17217.8 SQI 4/8 YE 4044211148706 10 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 54 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17218.8 SQI 4/9 YE 4044211148713 10 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 60.1 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17219.8 SQI 4/10 YE 4044211148720 10 Creation date 17.12.2023 18:04:23 Subject to technical changes 10 Data sheet 17104.7 SRK 4/2A WH Insulated cross-connector Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 29.6 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17214.8 SQI 4/5 YE 4044211148676 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 35.7 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17215.8 SQI 4/6 YE 4044211148683 20 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 23.5 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17213.8 SQI 4/4 YE 4044211148669 20 Insulated cross-connector, No. of poles: 30, Mounting type: Plug in, Width: 181.1 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17220.8 SQI 4/30 YE 4044211148737 5 Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 41.8 mm, Rated cross-section: 4 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17216.8 SQI 4/7 YE 4044211148690 20 Creation date 17.12.2023 18:04:23 Subject to technical changes 11 Data sheet 17104.7 SRK 4/2A WH Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Test adapters Test adapter, Length: 70 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17260.2 STA 5/1 BG 4044211171599 10 ST Test adapter, Length: 70 mm, Pitch size: 1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17261.2 STA ZP1 BG 4044211171605 10 ST ##INVERSE##CONTA-CONNECT Test adapter, Length: 70 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17260.2 STA 5/1 BG 4044211171599 10 ST Creation date 17.12.2023 18:04:23 Subject to technical changes 12 Data sheet 17104.7 SRK 4/2A WH ##INVERSE##CONTA-CONNECT Test adapter, Length: 70 mm, Pitch size: 1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17261.2 STA ZP1 BG 4044211171605 10 ST Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 2.5 mm², Width: 5.9 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17120.2 SMAG 4/2,5 BG 4044211172107 10 ST Creation date 17.12.2023 18:04:23 Subject to technical changes 13
17104.7 价格&库存
很抱歉,暂时无法提供与“17104.7”相匹配的价格&库存,您可以联系我们找货
