17117.6
17117.6
    CONTA-CLIP
    FEED-THROUGH TERMINAL
17117.6 数据手册
Data sheet 17117.6 SRK 6/2A SAS GR Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Grey RAL: 7030 Business data Article number 17117.6 Article name SRK 6/2A SAS GR GTIN (EAN) 4044211170349 Packaging unit 80 Quantity unit PC Weight per piece (not including packaging) 13.4 g Weight per piece (including packaging) 14.26 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 17117.2 Product description Feed-through terminal Creation date 16.12.2023 08:36:49 Subject to technical changes 1 Data sheet 17117.6 SRK 6/2A SAS GR Technical data Dimensions Length 62.5 mm Width 8 mm Height TS 35/7.5 47 mm Ratings Rated voltage 320 V Rated current 41 A Current load, max. 57 A Rated cross-section 10 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.31 W Creation date 16.12.2023 08:36:49 Subject to technical changes 2 Data sheet 17117.6 SRK 6/2A SAS GR Technical data Connection data Connection principle Screw connection Connection position Lateral Connections 4 Special connection Spade flat plug Faston 2.8 mm Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 6 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 8 Stripping length 10 mm Screw head Slotted Screw threading M 3,5 Wire cross-section single-core (rigid) / stranded, AWGmax. 8 Wire cross-section single-core (rigid) / stranded, AWGmin. 22 Wire cross-section stranded, AWG max. 8 Wire cross-section stranded, AWG min. 22 Wire cross-section stranded with wire-end ferrules, AWG max. 10 Wire cross-section stranded with wire-end ferrules, AWG min. 22 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A5 Number of cross-connection channels 2 End plate required Number of test pick-off options Creation date 16.12.2023 08:36:49 1 Subject to technical changes 3 Data sheet 17117.6 SRK 6/2A SAS GR Technical data Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 08:36:49 No Subject to technical changes 4 Data sheet 17117.6 SRK 6/2A SAS GR Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes German Lloyd approval DNV GL Certificate number TAE00002JG DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 6 mm² DNV GL rated current 57 A DNV GL rated impulse voltage 8 kV DNV GL rated voltage 1000 V DNV GL test standard IEC 60947-7-1:2009 Creation date 16.12.2023 08:36:49 Subject to technical changes 5 Data sheet 17117.6 SRK 6/2A SAS GR Media Creation date 16.12.2023 08:36:49 Subject to technical changes 6 Data sheet 17117.6 SRK 6/2A SAS GR Accessories Cover Cover, Width: 8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17297.8 SAD 1/8/B YE 4044211205454 50 ST Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 4 mm², Width: 6.6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17121.2 SMAG 6/4 BG 4044211172114 10 ST End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2001.2 AP 2,5-10 BG 4044211047979 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulation cap for cross-connector Creation date 16.12.2023 08:36:49 Subject to technical changes 7 Data sheet 17117.6 SRK 6/2A SAS GR Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 Insulated cross-connector Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 54.8 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17226.8 SQI 6/7 YE 4044211148799 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 62.9 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17227.8 SQI 6/8 YE 4044211148805 10 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 30.5 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17223.8 SQI 6/4 YE 4044211148768 20 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 71 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17228.8 SQI 6/9 YE 4044211148812 10 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 79.1 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17229.8 SQI 6/10 YE 4044211148829 10 Creation date 16.12.2023 08:36:49 Subject to technical changes 8 Data sheet 17117.6 SRK 6/2A SAS GR Insulated cross-connector Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 14.3 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17221.8 SQI 6/2 YE 4044211148744 50 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 22.4 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17222.8 SQI 6/3 YE 4044211148751 50 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 46.7 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17225.8 SQI 6/6 YE 4044211148782 20 Insulated cross-connector, No. of poles: 30, Mounting type: Plug in, Width: 240 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17230.8 SQI 6/30 YE 4044211148836 5 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 38.6 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17224.8 SQI 6/5 YE 4044211148775 20 Creation date 16.12.2023 08:36:49 Subject to technical changes 9 Data sheet 17117.6 SRK 6/2A SAS GR Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Partition plate Partition plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2002.2 TW 2,5-10 BG 4044211048044 50 Test adapters Test adapter, Length: 70 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17260.2 STA 5/1 BG 4044211171599 10 ST Test adapter, Length: 70 mm, Pitch size: 3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17262.2 STA ZP3 BG 4044211171612 10 ST ##INVERSE##CONTA-CONNECT Creation date 16.12.2023 08:36:49 Subject to technical changes 10 Data sheet 17117.6 SRK 6/2A SAS GR Test adapter, Length: 70 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17260.2 STA 5/1 BG 4044211171599 10 ST Test adapter, Length: 70 mm, Pitch size: 3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17262.2 STA ZP3 BG 4044211171612 10 ST Creation date 16.12.2023 08:36:49 Subject to technical changes 11
17117.6 价格&库存
很抱歉,暂时无法提供与“17117.6”相匹配的价格&库存,您可以联系我们找货
