17124.5
17124.5
    CONTA-CLIP
    FEED-THROUGH TERMINAL
17124.5 数据手册
Data sheet 17124.5 SRK 16/2A BU Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 17124.5 Article name SRK 16/2A BU GTIN (EAN) 4044211180973 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 27.9 g Weight per piece (including packaging) 29.6 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 17124.2 Product description Feed-through terminal Creation date 15.12.2023 07:59:55 Subject to technical changes 1 Data sheet 17124.5 SRK 16/2A BU Technical data Dimensions Length 53 mm Width 12.1 mm Height TS 35/7.5 55 mm Ratings Rated voltage 1000 V Rated current 76 A Current load, max. 101 A Rated cross-section 16 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.43 W Creation date 15.12.2023 07:59:55 Subject to technical changes 2 Data sheet 17124.5 SRK 16/2A BU Technical data Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 1.5 mm² Wire cross-section single core (rigid)/stranded, max. 25 mm² Wire cross-section stranded, min. 1.5 mm² Wire cross-section stranded, max. 25 mm² Wire cross-section stranded with wire-end ferrules,min. 1 mm² Wire cross-section stranded with wire-end ferrules,max. 16 mm² Wire cross-section AWG, min. 16 Wire cross-section AWG, max. 4 Stripping length 14 mm Screw head Slotted Screw threading M5 Tightening torque, min. 2.5 Nm Tightening torque, max. 3 Nm Wire cross-section single-core (rigid) / stranded, AWGmax. 4 Wire cross-section single-core (rigid) / stranded, AWGmin. 16 Wire cross-section stranded, AWG max. 4 Wire cross-section stranded, AWG min. 16 Wire cross-section stranded with wire-end ferrules, AWG max. 6 Wire cross-section stranded with wire-end ferrules, AWG min. 16 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 15.12.2023 07:59:55 Subject to technical changes 3 Data sheet 17124.5 SRK 16/2A BU Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A7 Number of cross-connection channels 2 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 15.12.2023 07:59:55 Subject to technical changes 4 Data sheet 17124.5 SRK 16/2A BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 80 A CSA wire cross-section AWG, min. 16 CSA wire cross-section AWG, max. 4 CSA torque, max. 3 Nm CSA torque, min. 2.5 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 80 A CSAus wire cross-section AWG, min. 16 CSAus wire cross-section AWG, max. 4 CSAus torque, min. 2.5 Nm CSAus torque, max. 3 Nm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 76 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 1.5 mm² KEMA wire cross-section single-core (rigid), max. 16 mm² KEMA wire cross-section stranded, min. 1.5 mm² KEMA wire cross-section stranded, max. 16 mm² KEMA torque, min. 2.5 Nm KEMA torque, max. 3 Nm Creation date 15.12.2023 07:59:55 Subject to technical changes 5 Data sheet 17124.5 SRK 16/2A BU Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 80 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 80 A UL wire cross-section single-core (rigid) AWG, min. 16 UL wire cross-section single-core (rigid) AWG, max. 4 UL wire cross-section stranded AWG, min. 16 UL wire cross-section stranded AWG, max. 4 UL torque, min. 22.1 Lb In. UL torque, max. 26.5 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 07:59:55 Subject to technical changes 6 Data sheet 17124.5 SRK 16/2A BU Media Creation date 15.12.2023 07:59:55 Subject to technical changes 7 Data sheet 17124.5 SRK 16/2A BU Accessories Cover Cover, Colour: White Article number Article name GTIN (EAN) Packaging unit 17248.7 SAD 1/12/B WH 4044211181123 20 ST Cover, Length: 33.25 mm, Width: 12 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17249.8 SAD 1/12/B YE 4044211199210 20 ST Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 6 mm², Width: 8.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17135.2 SMAG 16/6 BG 4044211181093 10 ST End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17254.2 SAP 16/2A BG 4044211181109 20 Creation date 15.12.2023 07:59:55 Subject to technical changes 8 Data sheet 17124.5 SRK 16/2A BU End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulated cross-connector Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 20 mm, Rated cross-section: 16 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17247.8 SQI 16/2 YE 4044211181116 20 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST ##INVERSE##CONTA-CONNECT Creation date 15.12.2023 07:59:55 Subject to technical changes 9 Data sheet 17124.5 SRK 16/2A BU Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 6 mm², Width: 8.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17135.2 SMAG 16/6 BG 4044211181093 10 ST Creation date 15.12.2023 07:59:55 Subject to technical changes 10
17124.5 价格&库存
很抱歉,暂时无法提供与“17124.5”相匹配的价格&库存,您可以联系我们找货
