17147.2
17147.2
    CONTA-CLIP
    EARTH TERMINAL
17147.2 数据手册
Data sheet 17147.2 SSL 35/2A/IS GNYE Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Green-yellow Business data Article number 17147.2 Article name SSL 35/2A/IS GNYE GTIN (EAN) 4044211186678 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 84 g Weight per piece (including packaging) 86.7 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Protective earth terminal Colour Green-yellow Creation date 15.12.2023 18:21:57 Subject to technical changes 1 Data sheet 17147.2 SSL 35/2A/IS GNYE Technical data Dimensions Length 59 mm Width 16.1 mm Height TS 35/7.5 65.5 mm Ratings Rated cross-section 35 mm² Overvoltage category III Contamination degree 3 Creation date 15.12.2023 18:21:57 Subject to technical changes 2 Data sheet 17147.2 SSL 35/2A/IS GNYE Technical data Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 1.5 mm² Wire cross-section single core (rigid)/stranded, max. 50 mm² Wire cross-section stranded, min. 1.5 mm² Wire cross-section stranded, max. 50 mm² Wire cross-section stranded with wire-end ferrules,min. 1.5 mm² Wire cross-section stranded with wire-end ferrules,max. 35 mm² Wire cross-section AWG, min. 16 Wire cross-section AWG, max. 1/0 Stripping length 18 mm Screw head Inner hex (Allen) Screw threading M6 Tightening torque, min. 3.2 Nm Tightening torque, max. 3.7 Nm Wire cross-section single-core (rigid) / stranded, AWGmax. 1/0 Wire cross-section single-core (rigid) / stranded, AWGmin. 16 Wire cross-section stranded, AWG max. 1/0 Wire cross-section stranded, AWG min. 16 Wire cross-section stranded with wire-end ferrules,AWG max. 2 Wire cross-section stranded with wire-end ferrules, AWG min. 16 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 B9 Number of cross-connection channels 1 Number of test pick-off options 1 Creation date 15.12.2023 18:21:57 Subject to technical changes 3 Data sheet 17147.2 SSL 35/2A/IS GNYE Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 18:21:57 Subject to technical changes 4 Data sheet 17147.2 SSL 35/2A/IS GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA wire cross-section AWG, min. 16 CSA wire cross-section AWG, max. 1/0 CSA torque, max. 3.7 Nm CSA torque, min. 3.2 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus wire cross-section AWG, min. 16 CSAus wire cross-section AWG, max. 1/0 CSAus torque, min. 3.2 Nm CSAus torque, max. 3.7 Nm KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 2.5 mm² KEMA wire cross-section single-core (rigid), max. 35 mm² KEMA wire cross-section stranded, min. 2.5 mm² KEMA wire cross-section stranded, max. 35 mm² KEMA torque, min. 3.2 Nm KEMA torque, max. 3.7 Nm Creation date 15.12.2023 18:21:57 Subject to technical changes 5 Data sheet 17147.2 SSL 35/2A/IS GNYE Approvals UL Recognized UL approval UL 1059 UL wire cross-section single-core (rigid) AWG, min. 16 UL wire cross-section single-core (rigid) AWG, max. 1/0 UL wire cross-section stranded AWG, min. 16 UL wire cross-section stranded AWG, max. 1/0 UL torque, min. 28.3 Lb In. UL torque, max. 32.7 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 18:21:57 Subject to technical changes 6 Data sheet 17147.2 SSL 35/2A/IS GNYE Media Creation date 15.12.2023 18:21:57 Subject to technical changes 7 Data sheet 17147.2 SSL 35/2A/IS GNYE Accessories Cover Cover, Length: 40.25 mm, Width: 16 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17281.8 SAD 1/16/B YE 4044211199661 20 ST Cover, Length: 40.25 mm, Width: 16 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 17282.7 SAD 1/16/B WH 4044211199654 20 ST Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 6 mm², Width: 8.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17148.2 SMAG 35/6 BG 4044211186685 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Creation date 15.12.2023 18:21:57 Subject to technical changes 8 Data sheet 17147.2 SSL 35/2A/IS GNYE Allen key socket wrench Inner hex key with bare blade Article number Article name GTIN (EAN) Packaging unit 2818.0 ISKS 5 4044211055448 1 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST ##INVERSE##CONTA-CONNECT Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 6 mm², Width: 8.3 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17148.2 SMAG 35/6 BG 4044211186685 50 Creation date 15.12.2023 18:21:57 Subject to technical changes 9
17147.2 价格&库存
很抱歉,暂时无法提供与“17147.2”相匹配的价格&库存,您可以联系我们找货
  • 20+80.1294320+10.37819
