17161.5
17161.5
    CONTA-CLIP
    FEED-THROUGH TERMINAL
17161.5 数据手册
Data sheet 17161.5 SRK 70/2A BU Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 70 mm², Width: 20.5 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 17161.5 Article name SRK 70/2A BU GTIN (EAN) 4044211189280 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 141 g Weight per piece (including packaging) 151 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 17161.2 Product description Feed-through terminal Creation date 16.12.2023 20:47:56 Subject to technical changes 1 Data sheet 17161.5 SRK 70/2A BU Technical data Dimensions Length 76.5 mm Width 20.5 mm Height TS 35/7.5 84 mm Ratings Rated voltage 1000 V Rated current 192 A Current load, max. 232 A Rated cross-section 70 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 6.14 W Creation date 16.12.2023 20:47:56 Subject to technical changes 2 Data sheet 17161.5 SRK 70/2A BU Technical data Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 10 mm² Wire cross-section single core (rigid)/stranded, max. 95 mm² Wire cross-section stranded, min. 10 mm² Wire cross-section stranded, max. 70 mm² Wire cross-section stranded with wire-end ferrules,min. 10 mm² Wire cross-section stranded with wire-end ferrules,max. 70 mm² Wire cross-section AWG, min. 6 Wire cross-section AWG, max. 000 Stripping length 22 mm Screw head Inner hex (Allen) Screw threading M8 Tightening torque, min. 6 Nm Tightening torque, max. 12 Nm Wire cross-section single-core (rigid) / stranded, AWGmax. 000 Wire cross-section single-core (rigid) / stranded, AWGmin. 6 Wire cross-section stranded, AWG max. 000 Wire cross-section stranded, AWG min. 6 Wire cross-section stranded with wire-end ferrules, AWG max. 00 Wire cross-section stranded with wire-end ferrules, AWG min. 6 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 B11 Number of cross-connection channels 1 Number of test pick-off options 1 Creation date 16.12.2023 20:47:56 Subject to technical changes 3 Data sheet 17161.5 SRK 70/2A BU Technical data Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:47:56 No Subject to technical changes 4 Data sheet 17161.5 SRK 70/2A BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 205 A cUL Usegroup C: rated voltage 600 V cUL Usegroup D: rated voltage 600 V cUL Usegroup D: rated current 205 A cUL Usegroup E: rated voltage 1000 V cUL Usegroup E: rated current 205 A cUL wire cross-section single-core (rigid) AWG, min. 6 cUL wire cross-section single-core (rigid) AWG, max. 3/0 cUL wire cross-section stranded AWG, min. 6 cUL wire cross-section stranded AWG, max. 3/0 cUL torque, min. 6 Nm cUL torque, max. 12 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 192 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 10 mm² KEMA wire cross-section single-core (rigid), max. 95 mm² KEMA wire cross-section stranded, min. 10 mm² KEMA wire cross-section stranded, max. 95 mm² KEMA torque, min. 6 Nm KEMA torque, max. 12 Nm Creation date 16.12.2023 20:47:56 Subject to technical changes 5 Data sheet 17161.5 SRK 70/2A BU Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 205 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 205 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 205 A UL Usegroup E: rated voltage 1000 V UL Usegroup E: rated current 205 A UL wire cross-section single-core (rigid) AWG, min. 6 UL wire cross-section single-core (rigid) AWG, max. 3/0 UL wire cross-section stranded AWG, min. 6 UL wire cross-section stranded AWG, max. 3/0 UL torque, min. 53.1 Lb In. UL torque, max. 106.2 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:47:56 Subject to technical changes 6 Data sheet 17161.5 SRK 70/2A BU Media Creation date 16.12.2023 20:47:56 Subject to technical changes 7 Data sheet 17161.5 SRK 70/2A BU Accessories Cover Cover, Length: 55.5 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17285.8 SAD 1/20/B YE 4044211205546 10 ST Cover, Length: 55.5 mm, Width: 20 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 17286.7 SAD 1/20/B WH 4044211205553 10 ST Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1121.2 MAG 50 BG 4044211080914 10 ST Inlay profile Inlay plate, Colour: natural Article number Article name GTIN (EAN) Packaging unit 2274.0 EP 50 4044211050818 10 ST Creation date 16.12.2023 20:47:56 Subject to technical changes 8 Data sheet 17161.5 SRK 70/2A BU Allen key socket wrench Inner hex key with bare blade Article number Article name GTIN (EAN) Packaging unit 2772.0 ISKS 6 4044211055028 1 ST Cross-connector Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 75.3 mm, Rated cross-section: 70 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17267.0 SQ 70/4 4044211186869 10 ST Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 34.3 mm, Rated cross-section: 70 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17265.0 SQ 70/2 4044211186845 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 54.8 mm, Rated cross-section: 70 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 17266.0 SQ 70/3 4044211186852 10 ST Creation date 16.12.2023 20:47:56 Subject to technical changes 9
17161.5 价格&库存
很抱歉,暂时无法提供与“17161.5”相匹配的价格&库存,您可以联系我们找货
  • 10+242.4431310+31.40626
