17175.4
17175.4
    CONTA-CLIP
    FUSE DISCONNECT TERMINAL
17175.4 数据手册
Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black RAL: 9005 Business data Article number 17175.4 Article name SSIK 6/2A/LED 12-30V AC/DC BK GTIN (EAN) 4044211188924 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 25.3 g Weight per piece (including packaging) 26.38 g Unit of weight G Customs number 85369010 Country of origin DE Product description Fuse-disconnect terminal Colour Black Creation date 16.12.2023 20:44:37 Subject to technical changes 1 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Technical data Dimensions Length 59 mm Width 8.1 mm Height TS 35/7.5 84 mm Ratings Rated voltage (determined by the illuminated display and fuse being used) 30 V Rated current (as fuse-disconnect terminal) 10 A Rated cross-section 6 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 2 / extraction lever Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 6 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 8 Stripping length 10 mm Screw head Slotted Screw threading M 3,5 Tightening torque, min. 0.8 Nm Tightening torque, max. 1.6 Nm Creation date 16.12.2023 20:44:37 Subject to technical changes 2 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Technical data Materials Insulation housing Polyamide 6.6 Glass-fibre reinforced Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 140 °C Further technical data Mounting type Mounting rail TS 35/7,5 Fuse size 6,3 x 25 / 6,3 x 32 mm Gauge plug acc. to EN 60 947-1 A5 Number of cross-connection channels 2 End plate required Voltage fuse 250 V Voltage illuminated display 12-30 V Cross-current via illuminated display < 5 mA Power loss in singular arrangement - overload and short-circuit protection, max. 2,5 / 2,5 W / A Power loss in compound arrangement - overload and short-circuit protection, max. 2,5 / 2,5 W / A Power loss in singular arrangement - only short-circuit protection, max. 4 / 10 W / A Power loss in compound arrangement - only short-circuit protection, max. 2,5 / 2,5 W / A Version of fuse holder Swivelling Type of display element (defect display) LED Version of fuse cartridge G fuse 6.3 x 25 / 6.3 x 32 Supply voltage (defect display), min. 12 Supply voltage (defect display), max. 30 Type of voltage (defect display) AC/DC Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:44:37 Subject to technical changes 3 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Approvals CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 10 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 8 CSA stripping length 10 mm CSA torque, max. 16 Nm CSA torque, min. 8 Nm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 10 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 8 CSAus stripping length 10 mm CSAus torque, min. 0.8 Nm CSAus torque, max. 1.6 Nm Creation date 16.12.2023 20:44:37 Subject to technical changes 4 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-3:2009 KEMA KEUR approval granted yes KEMA rated voltage 30 V KEMA voltage fuse, max. 250 V KEMA rated current 10 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 10 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 10 mm² KEMA stripping length 10 mm KEMA torque, min. 0.8 Nm KEMA torque, max. 1.6 Nm KEMA fuse size 6,3 x 25 / 6,3 x 32 mm KEMA power loss in singular arrangement - overloadand short-circuit protection, max. 2,5 / 2,5 W / A KEMA power loss in compound arrangement - overload and short-circuit protection, max. 2,5 / 2,5 W / A KEMA power loss in singular arrangement - only short-circuit protection, max. 4 / 10 W / A KEMA power loss in compound arrangement - only short-circuit protection, max. 2,5 / 2,5 W / A Creation date 16.12.2023 20:44:37 Subject to technical changes 5 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 10 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 10 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 8 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 8 UL torque, min. 7.08 Lb In. UL torque, max. 14.16 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:44:37 Subject to technical changes 6 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Media Creation date 16.12.2023 20:44:37 Subject to technical changes 7 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Accessories Measurement pick-off terminal Measurement pick-off terminal, Screw connection, Mounting type: On base, Rated crosssection: 4 mm², Width: 6.6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17121.2 SMAG 6/4 BG 4044211172114 10 ST End plate End plate, Width: 1.5 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17258.4 SAP SSIK 4/6 BK 4044211179830 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 Insulated cross-connector Creation date 16.12.2023 20:44:37 Subject to technical changes 8 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 54.8 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17226.8 SQI 6/7 YE 4044211148799 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 62.9 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17227.8 SQI 6/8 YE 4044211148805 10 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 30.5 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17223.8 SQI 6/4 YE 4044211148768 20 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 71 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17228.8 SQI 6/9 YE 4044211148812 10 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 79.1 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17229.8 SQI 6/10 YE 4044211148829 10 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 14.3 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17221.8 SQI 6/2 YE 4044211148744 50 Creation date 16.12.2023 20:44:37 Subject to technical changes 9 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 22.4 mm,Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17222.8 SQI 6/3 YE 4044211148751 50 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 46.7 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17225.8 SQI 6/6 YE 4044211148782 20 Insulated cross-connector, No. of poles: 30, Mounting type: Plug in, Width: 240 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17230.8 SQI 6/30 YE 4044211148836 5 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 38.6 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17224.8 SQI 6/5 YE 4044211148775 20 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Connecting sleeve Creation date 16.12.2023 20:44:37 Subject to technical changes 10 Data sheet 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2876.3 VBS 3/10/Z OG 4044211056018 20 ST Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2875.3 VBS 2/10/Z OG 4044211056001 20 ST Creation date 16.12.2023 20:44:37 Subject to technical changes 11
17175.4 价格&库存
很抱歉,暂时无法提供与“17175.4”相匹配的价格&库存,您可以联系我们找货
  • 50+130.4531450+16.89601
