17182.2
17182.2
    CONTA-CLIP
    EARTH DOUBLE-LEVEL TERMINAL
17182.2 数据手册
Data sheet 17182.2 SSLD 2,5 GNYE Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Business data Article number 17182.2 Article name SSLD 2,5 GNYE GTIN (EAN) 4044211190705 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 20.66 g Weight per piece (including packaging) 20.76 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Protective-earth double-level terminal Colour Green-yellow Creation date 15.12.2023 19:49:21 Subject to technical changes 1 Data sheet 17182.2 SSLD 2,5 GNYE Technical data Dimensions Length 76 mm Width 5.1 mm Height TS 35/7.5 65 mm Ratings Rated cross-section 2.5 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 4 Number of terminals per level 2 Number of levels 2 Levels internally bridged Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 10 mm Screw head Slotted Screw threading M 2,5 Tightening torque, min. 0.4 Nm Tightening torque, max. 0.8 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 15.12.2023 19:49:21 Subject to technical changes 2 Data sheet 17182.2 SSLD 2,5 GNYE Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 2 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 19:49:21 Subject to technical changes 3 Data sheet 17182.2 SSLD 2,5 GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque, min. 0.4 Nm cUL torque, max. 0.8 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL torque, min. 3.5 Lb In. UL torque, max. 7 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 19:49:21 Subject to technical changes 4 Data sheet 17182.2 SSLD 2,5 GNYE Media Creation date 15.12.2023 19:49:21 Subject to technical changes 5 Data sheet 17182.2 SSLD 2,5 GNYE Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17292.2 SAPD 2,5-4 BG 4044211190828 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 20.1 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17203.8 SQI 2,5/4 YE 4044211148560 20 Creation date 15.12.2023 19:49:21 Subject to technical changes 6 Data sheet 17182.2 SSLD 2,5 GNYE Insulated cross-connector Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 30.3 mm,Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17205.8 SQI 2,5/6 YE 4044211148584 20 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 45.6 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17208.8 SQI 2,5/9 YE 4044211148614 10 Insulated cross-connector, No. of poles: 30, Mounting type: Plug in, Width: 152.7 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17210.8 SQI 2,5/30 YE 4044211148638 5 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 15 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17202.8 SQI 2,5/3 YE 4044211148553 50 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 25.2 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17204.8 SQI 2,5/5 YE 4044211148577 20 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.9 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17201.8 SQI 2,5/2 YE 4044211148546 50 Creation date 15.12.2023 19:49:21 Subject to technical changes 7 Data sheet 17182.2 SSLD 2,5 GNYE Insulated cross-connector Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 35.4 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17206.8 SQI 2,5/7 YE 4044211148591 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 40.5 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17207.8 SQI 2,5/8 YE 4044211148607 10 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.7 mm, Rated cross-section: 2.5 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17209.8 SQI 2,5/10 YE 4044211148621 10 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Creation date 15.12.2023 19:49:21 Subject to technical changes 8
17182.2 价格&库存
很抱歉,暂时无法提供与“17182.2”相匹配的价格&库存,您可以联系我们找货
