1719.2
1719.2
    CONTA-CLIP
    EX FEED-THROUGH TERMINAL CERTIFI
1719.2 数据手册
Data sheet 1719.2 ZRK 6/2A Ex BG Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Business data Article number 1719.2 Article name ZRK 6/2A Ex BG GTIN (EAN) 4044211059279 Explosion-proof version (EEx e) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 16.8 g Weight per piece (including packaging) 17.8 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1719.2 Product description Ex feed-through terminal ATEX-certified Creation date 16.12.2023 09:48:25 Subject to technical changes 1 Data sheet 1719.2 ZRK 6/2A Ex BG Technical data Dimensions Length 65 mm Width 8.1 mm Height TS 35/7.5 47.5 mm Ratings Rated voltage 1000 V Rated current 41 A Rated cross-section 6 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.31 W Connection data Connection principle Tension-spring connection Connection position Diagonal Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 6 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 8 Stripping length 13 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 09:48:25 Subject to technical changes 2 Data sheet 1719.2 ZRK 6/2A Ex BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A5 Number of cross-connection channels 1 End plate required Number of test pick-off options 2 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 09:48:25 No Subject to technical changes 3 Data sheet 1719.2 ZRK 6/2A Ex BG Approvals Standards and regulations ATEX certification number TÜV ATEX 7093 U EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 50 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 8 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 50 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 8 CSAus stripping length 10 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 50 A cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 50 A cUL Usegroup D: rated voltage 600 V cUL Usegroup D: rated current 50 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 8 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 8 cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 09:48:25 Subject to technical changes 4 Data sheet 1719.2 ZRK 6/2A Ex BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 41 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 5 mm² KEMA wire cross-section single-core (rigid), max. 10 mm² KEMA wire cross-section stranded, min. 5 mm² KEMA wire cross-section stranded, max. 10 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 50 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 50 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 50 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 8 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 8 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 09:48:25 Subject to technical changes 5 Data sheet 1719.2 ZRK 6/2A Ex BG Approvals DNV GL Approval DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 6 mm² DNV GL rated current 41 A DNV GL rated voltage 800 V DNV GL test standard IEC 60947-7-1:2009 DNV GL wire cross-section single-core (rigid), max. 10 mm² DNV GL wire cross-section stranded, max. 6 mm² Creation date 16.12.2023 09:48:25 Subject to technical changes 6 Data sheet 1719.2 ZRK 6/2A Ex BG Media Creation date 16.12.2023 09:48:25 Subject to technical changes 7 Data sheet 1719.2 ZRK 6/2A Ex BG Accessories End plate End plate, Width: 2 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3760.2 ZAP 6/2A BG 4044211060817 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3748.2 ZES 35 BG 4044211060572 50 Insulated cross-connector Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 15.7 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3763.8 ZQI 6/2 YE 4044211060893 50 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 64.3 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3769.8 ZQI 6/8 YE 4044211060954 10 ST Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 72.4 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3770.8 ZQI 6/9 YE 4044211060961 10 ST Creation date 16.12.2023 09:48:25 Subject to technical changes 8 Data sheet 1719.2 ZRK 6/2A Ex BG Insulated cross-connector Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 23.8 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3764.8 ZQI 6/3 YE 4044211060909 50 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 31.9 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3765.8 ZQI 6/4 YE 4044211060916 20 ST Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 56.2 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3768.8 ZQI 6/7 YE 4044211060947 20 ST Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 31.9 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3766.8 ZQI 6/5 YE 4044211060923 20 ST Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 48.1 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3767.8 ZQI 6/6 YE 4044211060930 20 ST Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 80.5 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3771.8 ZQI 6/10 YE 4044211060978 10 ST Creation date 16.12.2023 09:48:25 Subject to technical changes 9 Data sheet 1719.2 ZRK 6/2A Ex BG Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Four-way cover Cover, Length: 10.5 mm, Width: 32.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3708.0 ZAD 6/4/B YE 4044211060268 20 ST Creation date 16.12.2023 09:48:25 Subject to technical changes 10
1719.2 价格&库存
很抱歉,暂时无法提供与“1719.2”相匹配的价格&库存,您可以联系我们找货
  • 100+21.66197100+2.80781
