17191.2
17191.2
    CONTA-CLIP
    DOUBLE-LEVEL TERMINAL
17191.2 数据手册
Data sheet 17191.2 SRKD 10/SV BG Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Business data Article number 17191.2 Article name SRKD 10/SV BG GTIN (EAN) 4044211190781 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 36.62 g Weight per piece (including packaging) 37.62 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 17191.2 Product description Double-level terminal Creation date 16.12.2023 02:43:39 Subject to technical changes 1 Data sheet 17191.2 SRKD 10/SV BG Technical data Dimensions Length 76 mm Width 10.1 mm Height TS 35/7.5 68 mm Ratings Rated voltage 1000 V Rated current 57 A Current load, max. 76 A Rated cross-section 10 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 3.65 W Connection data Connection principle Screw connection Connection position Lateral Connections 4 Number of terminals per level 2 Number of levels 2 Levels internally bridged Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 16 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 16 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 10 mm² Wire cross-section AWG, min. 18 Wire cross-section AWG, max. 6 Stripping length 10 mm Screw head Slotted Screw threading M4 Tightening torque, min. 1.2 Nm Tightening torque, max. 2.4 Nm Creation date 16.12.2023 02:43:39 Subject to technical changes 2 Data sheet 17191.2 SRKD 10/SV BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 B7 Number of cross-connection channels 2 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 02:43:39 No Subject to technical changes 3 Data sheet 17191.2 SRKD 10/SV BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 65 A cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 65 A cUL Usegroup D: rated voltage 600 V cUL Usegroup D: rated current 65 A cUL wire cross-section single-core (rigid) AWG, min. 18 cUL wire cross-section single-core (rigid) AWG, max. 6 cUL wire cross-section stranded AWG, min. 18 cUL wire cross-section stranded AWG, max. 6 cUL torque, min. 1.2 Nm cUL torque, max. 2.4 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 1000 V KEMA rated current 57 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 16 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 16 mm² Creation date 16.12.2023 02:43:39 Subject to technical changes 4 Data sheet 17191.2 SRKD 10/SV BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 65 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 65 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 65 A UL wire cross-section single-core (rigid) AWG, min. 18 UL wire cross-section single-core (rigid) AWG, max. 6 UL wire cross-section stranded AWG, min. 18 UL wire cross-section stranded AWG, max. 6 UL torque, min. 17.7 Lb In. UL torque, max. 35.4 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 02:43:39 Subject to technical changes 5 Data sheet 17191.2 SRKD 10/SV BG Media Creation date 16.12.2023 02:43:39 Subject to technical changes 6 Data sheet 17191.2 SRKD 10/SV BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17293.2 SAPD 10 BG 4044211190859 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 Insulated cross-connector Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 88.2 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17238.8 SQI 10/9 YE 4044211148911 10 Creation date 16.12.2023 02:43:39 Subject to technical changes 7 Data sheet 17191.2 SRKD 10/SV BG Insulated cross-connector Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 27.6 mm,Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17232.8 SQI 10/3 YE 4044211148850 50 Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 68 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17236.8 SQI 10/7 YE 4044211148898 20 Insulated cross-connector, No. of poles: 30, Mounting type: Plug in, Width: 300.3 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17240.8 SQI 10/30 YE 4044211148935 5 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 47.8 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17234.8 SQI 10/5 YE 4044211148874 20 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 17.5 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17231.8 SQI 10/2 YE 4044211148843 50 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 37.7 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17233.8 SQI 10/4 YE 4044211148867 20 Creation date 16.12.2023 02:43:39 Subject to technical changes 8 Data sheet 17191.2 SRKD 10/SV BG Insulated cross-connector Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 57.9 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17235.8 SQI 10/6 YE 4044211148881 20 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 98.3 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17239.8 SQI 10/10 YE 4044211148928 5 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 78.1 mm, Rated cross-section: 10 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17237.8 SQI 10/8 YE 4044211148904 10 Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Cover Creation date 16.12.2023 02:43:39 Subject to technical changes 9 Data sheet 17191.2 SRKD 10/SV BG Cover, Width: 10 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17298.8 SAD 1/10/B YE 4044211205461 50 ST Creation date 16.12.2023 02:43:39 Subject to technical changes 10
17191.2 价格&库存
很抱歉,暂时无法提供与“17191.2”相匹配的价格&库存,您可以联系我们找货
