17218.8
17218.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
17218.8 数据手册
Data sheet 17218.8 SQI 4/9 YE Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 54 mm, Rated cross-section: 4 mm², Colour: Yellow RAL: 1026 Business data Article number 17218.8 Article name SQI 4/9 YE GTIN (EAN) 4044211148713 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 6.5 g Weight per piece (including packaging) 6.6 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 17218.8 Product description Insulated cross-connector Creation date 15.12.2023 10:55:38 Subject to technical changes 1 Data sheet 17218.8 SQI 4/9 YE Technical data Dimensions Length 4 mm Width 54 mm Height 23 mm Pitch size 6 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 32 A Current load, max. 41 A Rated cross-section 4 mm² Contamination degree 2 Connection data No. of poles 9 Materials Material Bronze Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 9 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 10:55:38 No Subject to technical changes 2 Data sheet 17218.8 SQI 4/9 YE Media Creation date 15.12.2023 10:55:38 Subject to technical changes 3 Data sheet 17218.8 SQI 4/9 YE Accessories Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17566.2 SRKD 4/D5 BG 4044211234669 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17569.2 SRKD 4/RD5 BG 4044211234690 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17563.2 SRKD 4/D2 BG 4044211234638 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17564.2 SRKD 4/D3 BG 4044211234645 100 ST Creation date 15.12.2023 10:55:38 Subject to technical changes 4 Data sheet 17218.8 SQI 4/9 YE ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17565.2 SRKD 4/D4 BG 4044211234652 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17570.2 SRKD 4/LED1(RD)/24V DC BG 4044211234706 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17571.2 SRKD 4/LED1(GN)/24V DC BG 4044211234713 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17572.2 SRKD 4/LED2(RD)/24V DC BG 4044211234720 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17575.2 SRKD 4/LED3(GN)/24V DC BG 4044211234751 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17576.2 SRKD 4/LED4(RD)/24V DC BG 4044211234768 100 ST Creation date 15.12.2023 10:55:38 Subject to technical changes 5 Data sheet 17218.8 SQI 4/9 YE ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17578.2 SRKD 4/LED5(RD)/24V AC BG 4044211234782 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17579.2 SRKD 4/LED5(RD)/230V AC BG 4044211234799 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17561.2 SRKD 4/D0 BG 4044211234614 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17562.2 SRKD 4/D1 BG 4044211234621 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17567.2 SRKD 4/D6 BG 4044211234676 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17568.2 SRKD 4/RD1 BG 4044211234683 100 ST Creation date 15.12.2023 10:55:38 Subject to technical changes 6 Data sheet 17218.8 SQI 4/9 YE ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17573.2 SRKD 4/LED2(GN)/24V DC BG 4044211234737 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17574.2 SRKD 4/LED3(RD)/24V DC BG 4044211234744 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17577.2 SRKD 4/LED4(GN)/24V DC BG 4044211234775 100 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17172.4 SSIK 4/2A/LED 30-60V AC/DC BK 4044211180447 25 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17150.4 SSIK 4/2A BK 4044211179816 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17171.4 SSIK 4/2A/LED 12-30V AC/DC BK 4044211180430 25 ST Creation date 15.12.2023 10:55:38 Subject to technical changes 7 Data sheet 17218.8 SQI 4/9 YE ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17173.4 SSIK 4/2A/LED 110-250V AC/DC BK 4044211180454 25 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17174.4 SSIK 4/2A/LED 500V AC/DC BK 4044211180461 25 ST Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17185.2 SRKD 4 BG 4044211190712 100 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17186.2 SRKD 4/SV BG 4044211190736 100 Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17187.2 SSLD 4 GNYE 4044211190750 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17106.2 SRK 4/2A/Z BG 4044211141714 100 ST Creation date 15.12.2023 10:55:38 Subject to technical changes 8 Data sheet 17218.8 SQI 4/9 YE ##INVERSE##CONTA-CONNECT Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17107.2 SSL 4/2A GNYE 4044211141721 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17155.2 SRK 4/2A/PE BKYE 4044211186692 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17104.2 SRK 4/2A BG 4044211141691 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17105.2 SRK B 4/2A BG 4044211141707 100 ST Creation date 15.12.2023 10:55:38 Subject to technical changes 9
17218.8 价格&库存
很抱歉,暂时无法提供与“17218.8”相匹配的价格&库存,您可以联系我们找货
