17202.8
17202.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
17202.8 数据手册
Data sheet 17202.8 SQI 2,5/3 YE Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 15 mm, Rated cross-section: 2.5 mm², Colour: Yellow RAL: 1026 Business data Article number 17202.8 Article name SQI 2,5/3 YE GTIN (EAN) 4044211148553 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 1.7 g Weight per piece (including packaging) 1.73 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 17202.8 Product description Insulated cross-connector Creation date 16.12.2023 12:13:05 Subject to technical changes 1 Data sheet 17202.8 SQI 2,5/3 YE Technical data Dimensions Length 4 mm Width 15 mm Height 23 mm Pitch size 5 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 24 A Current load, max. 32 A Rated cross-section 2.5 mm² Contamination degree 2 Connection data No. of poles 3 Materials Material Bronze Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 3 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 12:13:05 No Subject to technical changes 2 Data sheet 17202.8 SQI 2,5/3 YE Media Creation date 16.12.2023 12:13:05 Subject to technical changes 3 Data sheet 17202.8 SQI 2,5/3 YE Accessories Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 ##INVERSE##CONTA-CONNECT Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17182.2 SSLD 2,5 GNYE 4044211190705 100 ST Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17180.2 SRKD 2,5 BG 4044211190668 100 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17181.2 SRKD 2,5/SV BG 4044211190682 100 Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17103.2 SSL 2,5/2A GNYE 4044211141684 100 ST Creation date 16.12.2023 12:13:05 Subject to technical changes 4 Data sheet 17202.8 SQI 2,5/3 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17100.2 SRK 2,5/2A BG 4044211141653 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17129.2 SRK 2,5/2A/PE BKYE 4044211200688 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17119.2 SRK 2,5/2A SAS BG 4044211149048 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17101.2 SRK B 2,5/2A BG 4044211141660 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17102.2 SRK 2,5/2A/Z BG 4044211141677 100 ST Creation date 16.12.2023 12:13:05 Subject to technical changes 5
17202.8 价格&库存
很抱歉,暂时无法提供与“17202.8”相匹配的价格&库存,您可以联系我们找货
  • 50+12.5534450+1.62619
