17222.8
17222.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
17222.8 数据手册
Data sheet 17222.8 SQI 6/3 YE Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 22.4 mm, Rated cross-section: 6 mm², Colour: Yellow RAL: 1026 Business data Article number 17222.8 Article name SQI 6/3 YE GTIN (EAN) 4044211148751 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 3.3 g Weight per piece (including packaging) 3.34 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 17222.8 Product description Insulated cross-connector Creation date 16.12.2023 05:20:04 Subject to technical changes 1 Data sheet 17222.8 SQI 6/3 YE Technical data Dimensions Length 4 mm Width 22.4 mm Height 23 mm Pitch size 8 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 41 A Current load, max. 41 A Rated cross-section 6 mm² Contamination degree 2 Connection data No. of poles 3 Materials Material Copper alloy Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 3 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 05:20:04 No Subject to technical changes 2 Data sheet 17222.8 SQI 6/3 YE Media Creation date 16.12.2023 05:20:04 Subject to technical changes 3 Data sheet 17222.8 SQI 6/3 YE Accessories Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 ##INVERSE##CONTA-CONNECT Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17523.2 SPTK 6/LT/HB BG 4044211209223 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17524.2 SPTK 6/LT/STBI/YE BG 4044211209919 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17151.4 SSIK 6/2A BK 4044211188993 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17176.4 SSIK 6/2A/LED 30-60V AC/DC BK 4044211188931 50 ST Creation date 16.12.2023 05:20:04 Subject to technical changes 4 Data sheet 17222.8 SQI 6/3 YE ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17178.4 SSIK 6/2A/LED 500V AC/DC BK 4044211188948 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17520.2 SPTK 6/DU BG 4044211209650 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17521.2 SPTK 6/LT BG 4044211209162 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17522.2 SPTK 6/QT BG 4044211209216 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17525.2 SPTK 6/LT/STBI/BU BG 4044211209926 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK 4044211188924 50 ST Creation date 16.12.2023 05:20:04 Subject to technical changes 5 Data sheet 17222.8 SQI 6/3 YE ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17177.4 SSIK 6/2A/LED 110-250V AC/DC BK 4044211188955 50 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17111.2 SSL 6/2A GNYE 4044211141769 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17132.2 SRK 6/2A/PE BKYE 4044211200718 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17109.2 SRK B 6/2A BG 4044211141745 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17108.2 SRK 6/2A BG 4044211141738 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17110.2 SRK 6/2A/Z BG 4044211141752 100 ST Creation date 16.12.2023 05:20:04 Subject to technical changes 6 Data sheet 17222.8 SQI 6/3 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17117.2 SRK 6/2A SAS BG 4044211149000 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87805.2 SRK 6/2A Ex BG 4044211199777 100 ##INVERSE##CONTA-CONNECT Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17521.2 SPTK 6/LT BG 4044211209162 50 ST Creation date 16.12.2023 05:20:04 Subject to technical changes 7
17222.8 价格&库存
很抱歉,暂时无法提供与“17222.8”相匹配的价格&库存,您可以联系我们找货
  • 50+16.0590250+2.07715
