17223.8
17223.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
17223.8 数据手册
Data sheet 17223.8 SQI 6/4 YE Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 30.5 mm, Rated cross-section: 6 mm², Colour: Yellow RAL: 1026 Business data Article number 17223.8 Article name SQI 6/4 YE GTIN (EAN) 4044211148768 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 4.4 g Weight per piece (including packaging) 4.47 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 17223.8 Product description Insulated cross-connector Creation date 16.12.2023 05:16:49 Subject to technical changes 1 Data sheet 17223.8 SQI 6/4 YE Technical data Dimensions Length 4 mm Width 30.5 mm Height 23 mm Pitch size 8 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 41 A Current load, max. 41 A Rated cross-section 6 mm² Contamination degree 2 Connection data No. of poles 4 Materials Material Copper alloy Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 4 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 05:16:49 No Subject to technical changes 2 Data sheet 17223.8 SQI 6/4 YE Media Creation date 16.12.2023 05:16:49 Subject to technical changes 3 Data sheet 17223.8 SQI 6/4 YE Accessories Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 ##INVERSE##CONTA-CONNECT Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17523.2 SPTK 6/LT/HB BG 4044211209223 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17524.2 SPTK 6/LT/STBI/YE BG 4044211209919 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17151.4 SSIK 6/2A BK 4044211188993 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17176.4 SSIK 6/2A/LED 30-60V AC/DC BK 4044211188931 50 ST Creation date 16.12.2023 05:16:49 Subject to technical changes 4 Data sheet 17223.8 SQI 6/4 YE ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17178.4 SSIK 6/2A/LED 500V AC/DC BK 4044211188948 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17520.2 SPTK 6/DU BG 4044211209650 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17521.2 SPTK 6/LT BG 4044211209162 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17522.2 SPTK 6/QT BG 4044211209216 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17525.2 SPTK 6/LT/STBI/BU BG 4044211209926 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK 4044211188924 50 ST Creation date 16.12.2023 05:16:49 Subject to technical changes 5 Data sheet 17223.8 SQI 6/4 YE ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17177.4 SSIK 6/2A/LED 110-250V AC/DC BK 4044211188955 50 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17111.2 SSL 6/2A GNYE 4044211141769 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17132.2 SRK 6/2A/PE BKYE 4044211200718 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17109.2 SRK B 6/2A BG 4044211141745 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17108.2 SRK 6/2A BG 4044211141738 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17110.2 SRK 6/2A/Z BG 4044211141752 100 ST Creation date 16.12.2023 05:16:49 Subject to technical changes 6 Data sheet 17223.8 SQI 6/4 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17117.2 SRK 6/2A SAS BG 4044211149000 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87805.2 SRK 6/2A Ex BG 4044211199777 100 ##INVERSE##CONTA-CONNECT Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17521.2 SPTK 6/LT BG 4044211209162 50 ST Creation date 16.12.2023 05:16:49 Subject to technical changes 7
17223.8
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和快速响应时间。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
17223.8 价格&库存
很抱歉,暂时无法提供与“17223.8”相匹配的价格&库存,您可以联系我们找货
  • 20+25.8282320+3.33421
