17235.8
17235.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
17235.8 数据手册
Data sheet 17235.8 SQI 10/6 YE Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 57.9 mm, Rated cross-section: 10 mm², Colour: Yellow RAL: 1026 Business data Article number 17235.8 Article name SQI 10/6 YE GTIN (EAN) 4044211148881 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 8g Weight per piece (including packaging) 8.1 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 17235.8 Product description Insulated cross-connector Creation date 16.12.2023 20:54:22 Subject to technical changes 1 Data sheet 17235.8 SQI 10/6 YE Technical data Dimensions Length 4 mm Width 57.9 mm Height 23 mm Pitch size 10 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 57 A Current load, max. 57 A Rated cross-section 10 mm² Contamination degree 2 Connection data No. of poles 6 Materials Material Copper alloy Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 6 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:54:22 No Subject to technical changes 2 Data sheet 17235.8 SQI 10/6 YE Media Creation date 16.12.2023 20:54:22 Subject to technical changes 3 Data sheet 17235.8 SQI 10/6 YE Accessories Insulation cap for cross-connector Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 ##INVERSE##CONTA-CONNECT Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17192.2 SSLD 10 GNYE 4044211190804 50 ST Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17190.2 SRKD 10 BG 4044211190767 50 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17191.2 SRKD 10/SV BG 4044211190781 50 Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17115.2 SSL 10/2A GNYE 4044211141806 100 ST Creation date 16.12.2023 20:54:22 Subject to technical changes 4 Data sheet 17235.8 SQI 10/6 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17113.2 SRK B 10/2A BG 4044211141783 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17112.2 SRK 10/2A BG 4044211141776 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17114.2 SRK 10/2A/Z BG 4044211141790 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17118.2 SRK 10/2A SAS BG 4044211149024 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17133.2 SRK 10/2A/PE BKYE 4044211200725 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87807.2 SRK 10/2A Ex BG 4044211199807 100 Creation date 16.12.2023 20:54:22 Subject to technical changes 5
17235.8 价格&库存
很抱歉,暂时无法提供与“17235.8”相匹配的价格&库存,您可以联系我们找货
