17250.2
17250.2
    CONTA-CLIP
    END BRACKET
17250.2 数据手册
Data sheet 17250.2 SES 35 BG End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Business data Article number 17250.2 Article name SES 35 BG GTIN (EAN) 4044211178253 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 7.85 g Weight per piece (including packaging) 7.95 g Unit of weight G Customs number 85389099 Country of origin CZ Prio-Article 17250.2 Product description End bracket Creation date 16.12.2023 20:48:05 Subject to technical changes 1 Data sheet 17250.2 SES 35 BG Technical data Dimensions Length 48 mm Width 8 mm Height TS 35/7.5 47.1 mm Height TS 35/15 56.8 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7,5 and TS 35/15 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:48:05 No Subject to technical changes 2 Data sheet 17250.2 SES 35 BG Media Creation date 16.12.2023 20:48:05 Subject to technical changes 3 Data sheet 17250.2 SES 35 BG Accessories Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9410.7 PMC BSTR 8x12/21 WH 4044211154998 210 ST ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17566.2 SRKD 4/D5 BG 4044211234669 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17569.2 SRKD 4/RD5 BG 4044211234690 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17563.2 SRKD 4/D2 BG 4044211234638 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 4 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17564.2 SRKD 4/D3 BG 4044211234645 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17565.2 SRKD 4/D4 BG 4044211234652 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17570.2 SRKD 4/LED1(RD)/24V DC BG 4044211234706 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17571.2 SRKD 4/LED1(GN)/24V DC BG 4044211234713 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17572.2 SRKD 4/LED2(RD)/24V DC BG 4044211234720 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17575.2 SRKD 4/LED3(GN)/24V DC BG 4044211234751 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 5 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17576.2 SRKD 4/LED4(RD)/24V DC BG 4044211234768 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17578.2 SRKD 4/LED5(RD)/24V AC BG 4044211234782 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17579.2 SRKD 4/LED5(RD)/230V AC BG 4044211234799 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17561.2 SRKD 4/D0 BG 4044211234614 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17562.2 SRKD 4/D1 BG 4044211234621 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17567.2 SRKD 4/D6 BG 4044211234676 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 6 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17568.2 SRKD 4/RD1 BG 4044211234683 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17573.2 SRKD 4/LED2(GN)/24V DC BG 4044211234737 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17574.2 SRKD 4/LED3(RD)/24V DC BG 4044211234744 100 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17577.2 SRKD 4/LED4(GN)/24V DC BG 4044211234775 100 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17523.2 SPTK 6/LT/HB BG 4044211209223 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17524.2 SPTK 6/LT/STBI/YE BG 4044211209919 50 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 7 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17151.4 SSIK 6/2A BK 4044211188993 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17172.4 SSIK 4/2A/LED 30-60V AC/DC BK 4044211180447 25 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17176.4 SSIK 6/2A/LED 30-60V AC/DC BK 4044211188931 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17178.4 SSIK 6/2A/LED 500V AC/DC BK 4044211188948 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17520.2 SPTK 6/DU BG 4044211209650 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17521.2 SPTK 6/LT BG 4044211209162 50 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 8 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17522.2 SPTK 6/QT BG 4044211209216 50 ST Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17525.2 SPTK 6/LT/STBI/BU BG 4044211209926 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17150.4 SSIK 4/2A BK 4044211179816 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17171.4 SSIK 4/2A/LED 12-30V AC/DC BK 4044211180430 25 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17173.4 SSIK 4/2A/LED 110-250V AC/DC BK 4044211180454 25 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17174.4 SSIK 4/2A/LED 500V AC/DC BK 4044211180461 25 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 9 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17175.4 SSIK 6/2A/LED 12-30V AC/DC BK 4044211188924 50 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17177.4 SSIK 6/2A/LED 110-250V AC/DC BK 4044211188955 50 ST Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17182.2 SSLD 2,5 GNYE 4044211190705 100 ST Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17192.2 SSLD 10 GNYE 4044211190804 50 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17111.2 SSL 6/2A GNYE 4044211141769 100 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17131.2 SSL 16/2A/IS GNYE 4044211181079 50 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 10 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17147.2 SSL 35/2A/IS GNYE 4044211186678 20 ST Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17180.2 SRKD 2,5 BG 4044211190668 100 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17181.2 SRKD 2,5/SV BG 4044211190682 100 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17185.2 SRKD 4 BG 4044211190712 100 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17186.2 SRKD 4/SV BG 4044211190736 100 Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17187.2 SSLD 4 GNYE 4044211190750 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 11 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17190.2 SRKD 10 BG 4044211190767 50 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17191.2 SRKD 10/SV BG 4044211190781 50 Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17103.2 SSL 2,5/2A GNYE 4044211141684 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17106.2 SRK 4/2A/Z BG 4044211141714 100 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17107.2 SSL 4/2A GNYE 4044211141721 100 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17115.2 SSL 10/2A GNYE 4044211141806 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 12 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17130.2 SSL 16/2A GNYE 4044211181062 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17132.2 SRK 6/2A/PE BKYE 4044211200718 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17134.2 SRK 16/2A/H BG 4044211206192 50 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17145.2 SSL 35/2A GNYE 4044211186661 20 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17100.2 SRK 2,5/2A BG 4044211141653 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17113.2 SRK B 10/2A BG 4044211141783 100 Creation date 16.12.2023 20:48:05 Subject to technical changes 13 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17124.2 SRK 16/2A BG 4044211180942 50 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17127.2 SRK 16/2A/Z/IS BG 4044211181048 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17128.2 SRK 16/2A/PE BKYE 4044211199739 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17129.2 SRK 2,5/2A/PE BKYE 4044211200688 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17141.2 SRK 35/2A/Z BG 4044211186630 20 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17143.2 SRK 35/2A/Z/IS BG 4044211186654 20 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 14 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17155.2 SRK 4/2A/PE BKYE 4044211186692 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 50 mm², Width: 18.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17156.2 SRK 50/2A BG 4044211186715 10 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17104.2 SRK 4/2A BG 4044211141691 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17105.2 SRK B 4/2A BG 4044211141707 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17109.2 SRK B 6/2A BG 4044211141745 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17112.2 SRK 10/2A BG 4044211141776 100 Creation date 16.12.2023 20:48:05 Subject to technical changes 15 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17119.2 SRK 2,5/2A SAS BG 4044211149048 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17125.2 SRK 16/2A/Z BG 4044211181024 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17140.2 SRK 35/2A BG 4044211186616 20 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17142.2 SRK 35/2A/IS BG 4044211186647 20 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 70 mm², Width: 20.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17161.2 SRK 70/2A BG 4044211189273 10 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 120 mm², Width: 27 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17167.2 SRK 120/2A/PE BKYE 4044211189396 5 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 16 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17101.2 SRK B 2,5/2A BG 4044211141660 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17102.2 SRK 2,5/2A/Z BG 4044211141677 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17108.2 SRK 6/2A BG 4044211141738 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17110.2 SRK 6/2A/Z BG 4044211141752 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17114.2 SRK 10/2A/Z BG 4044211141790 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17117.2 SRK 6/2A SAS BG 4044211149000 80 Creation date 16.12.2023 20:48:05 Subject to technical changes 17 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17126.2 SRK 16/2A/IS BG 4044211181031 50 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17126.2 SRK 16/2A/IS BG 4044211181031 50 EX-Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 87808.2 SSL 10/2A Ex GNYE 4044211199821 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17116.2 SRK 4/2A SAS BG 4044211148980 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17116.2 SRK 4/2A SAS BG 4044211148980 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17133.2 SRK 10/2A/PE BKYE 4044211200725 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 18 Data sheet 17250.2 SES 35 BG ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 50 mm², Width: 18.5 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17157.2 SRK 50/2A/PE BKYE 4044211186722 10 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 70 mm², Width: 20.5 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17162.2 SRK 70/2A/PE BKYE 4044211186777 10 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87807.2 SRK 10/2A Ex BG 4044211199807 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87805.2 SRK 6/2A Ex BG 4044211199777 100 ##INVERSE##CONTA-CONNECT Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17566.2 SRKD 4/D5 BG 4044211234669 100 ST Creation date 16.12.2023 20:48:05 Subject to technical changes 19
17250.2 价格&库存
很抱歉,暂时无法提供与“17250.2”相匹配的价格&库存,您可以联系我们找货
