17252.8
17252.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
17252.8 数据手册
Data sheet 17252.8 SQI 35/2 YE Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 26.5 mm, Rated cross-section: 35 mm², Colour: Yellow RAL: 1026 Business data Article number 17252.8 Article name SQI 35/2 YE GTIN (EAN) 4044211186807 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 14 g Weight per piece (including packaging) 14.2 g Unit of weight G Customs number 85389099 Country of origin DE Product description Insulated cross-connector Colour Yellow Creation date 15.12.2023 06:30:47 Subject to technical changes 1 Data sheet 17252.8 SQI 35/2 YE Technical data Dimensions Length 6.2 mm Width 26.5 mm Height 34.1 mm Pitch size 16 mm Ratings Max. voltage 1000 V Rated current 101 A Current load, max. 101 A Rated cross-section 35 mm² Contamination degree 2 Connection data No. of poles 2 Materials Material Bronze Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 2 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 06:30:47 Subject to technical changes 2 Data sheet 17252.8 SQI 35/2 YE Media Creation date 15.12.2023 06:30:47 Subject to technical changes 3 Data sheet 17252.8 SQI 35/2 YE Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17147.2 SSL 35/2A/IS GNYE 4044211186678 20 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17145.2 SSL 35/2A GNYE 4044211186661 20 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17141.2 SRK 35/2A/Z BG 4044211186630 20 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17143.2 SRK 35/2A/Z/IS BG 4044211186654 20 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17140.2 SRK 35/2A BG 4044211186616 20 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17142.2 SRK 35/2A/IS BG 4044211186647 20 Creation date 15.12.2023 06:30:47 Subject to technical changes 4 Data sheet 17252.8 SQI 35/2 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16.1 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17144.2 SRK 35/2A/PE BKYE 4044211199722 20 ST Creation date 15.12.2023 06:30:47 Subject to technical changes 5
17252.8 价格&库存
很抱歉,暂时无法提供与“17252.8”相匹配的价格&库存,您可以联系我们找货
  • 20+30.9429320+4.00766
