17293.1
17293.1
    CONTA-CLIP
    END PLATE
17293.1 数据手册
Data sheet 17293.1 SAPD 10 GN End plate, Width: 1.5 mm, Colour: Green Business data Article number 17293.1 Article name SAPD 10 GN GTIN (EAN) 4044211190842 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3.8 g Weight per piece (including packaging) 3.9 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 17293.2 Product description End plate Creation date 16.12.2023 20:45:36 Subject to technical changes 1 Data sheet 17293.1 SAPD 10 GN Technical data Dimensions Length 72 mm Width 1.5 mm Height 64.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:45:36 No Subject to technical changes 2 Data sheet 17293.1 SAPD 10 GN Media Creation date 16.12.2023 20:45:36 Subject to technical changes 3 Data sheet 17293.1 SAPD 10 GN Accessories ##INVERSE##CONTA-CONNECT Protective-earth double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17192.2 SSLD 10 GNYE 4044211190804 50 ST Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17190.2 SRKD 10 BG 4044211190767 50 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 10.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17191.2 SRKD 10/SV BG 4044211190781 50 Creation date 16.12.2023 20:45:36 Subject to technical changes 4
17293.1 价格&库存
很抱歉,暂时无法提供与“17293.1”相匹配的价格&库存,您可以联系我们找货
