Data sheet
17371.8 RK 35/35 N/IS YE
Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35
mm², Width: 16 mm, Colour: Yellow
RAL: 1026
Business data
Article number
17371.8
Article name
RK 35/35 N/IS YE
GTIN (EAN)
4044211186302
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
59.8 g
Weight per piece (including packaging)
62.9 g
Unit of weight
G
Customs number
85369010
Country of origin
DE
Prio-Article
17371.2
Product description
Creation date 16.12.2023 20:44:57
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
58 mm
Width
16 mm
Height TS 35/7.5
52 mm
Ratings
Rated voltage
800 V
Rated current
125 A
Rated cross-section
35 mm²
Rated impulse voltage
8 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
4W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
2.5 mm²
Wire cross-section single core (rigid)/stranded, max.
50 mm²
Wire cross-section stranded, min.
2.5 mm²
Wire cross-section stranded, max.
35 mm²
Wire cross-section stranded with wire-end ferrules,
min.
2.5 mm²
max.
35 mm²
Wire cross-section AWG, min.
12
Wire cross-section AWG, max.
2
Stripping length
20 mm
Screw head
Inner hex (Allen)
Screw threading
M6
Tightening torque, min.
2.5 Nm
Tightening torque, max.
5 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
B9
Number of cross-connection channels
1
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
115 A
CSA wire cross-section AWG, min.
12
CSA wire cross-section AWG, max.
2
CSA stripping length
20 mm
CSA File Number
042110_0_000
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
115 A
CSAus wire cross-section AWG, min.
12
CSAus wire cross-section AWG, max.
2
CSAus stripping length
20 mm
CSAus File Number
042110_0_000
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup C: rated voltage
600 V
cUL Usegroup C: rated current
115 A
cUL wire cross-section single-core (rigid) AWG, min.
12
cUL wire cross-section single-core (rigid) AWG, max. 2
cUL wire cross-section stranded AWG, min.
12
cUL wire cross-section stranded AWG, max.
2
cUL torque
40 Nm
cUL wire material
Cu
cUL File Number
E95701
cUL Recognized
1
4
Data sheet
Approvals
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
1000 V
KEMA rated current
125 A
KEMA rated impulse voltage
8 kV
KEMA wire cross-section single core (rigid), min.
2.5 mm²
KEMA wire cross-section single-core (rigid), max.
50 mm²
KEMA wire cross-section stranded, min.
2.5 mm²
KEMA wire cross-section stranded, max.
35 mm²
UL Recognized
UL approval
UL 1059
600 V
115 A
12
2
12
2
UL torque
40 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL File Number
E95701
UL Recognized
1
German Lloyd approval
DNV GL Certificate number
TAE00002JF
DNV GL Location Classes
Temperature: B, Humidity: B, Vibration: A
DNV GL approval granted
1
DNV GL rated cross-section
35 mm²
DNV GL rated current
125 A
DNV GL rated voltage
800 V
DNV GL test standard
IEC 60947-7-1:2002
5
Data sheet
Media
6
Data sheet
Accessories
Cover
Cover, Length: 37.3 mm, Width: 16 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2956.0
AD 1/16/N/B YE
4044211056841
20 ST
Cover, Length: 37.3 mm, Width: 16 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
2968.0
AD 1/16/N WH
4044211056971
20 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
7
