17381.6
17381.6
    CONTA-CLIP
    PANEL FEED-THROUGH TERMINAL
17381.6 数据手册
Data sheet 17381.6 SDK 4/2A/Z GR Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated cross-section: 4 mm², Colour: Grey RAL: 7032 Business data Article number 17381.6 Article name SDK 4/2A/Z GR GTIN (EAN) 4044211199234 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 14.11 g Weight per piece (including packaging) 14.14 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Panel feed-through terminal Colour Grey Creation date 17.12.2023 18:19:34 Subject to technical changes 1 Data sheet 17381.6 SDK 4/2A/Z GR Technical data Dimensions Length of outer part 27.5 mm Length of inner part 22.4 mm Width of outer part 8.1 mm Width of inner part 8.1 mm Height of outer part 28.2 mm Height of inner part 26.8 mm Ratings Rated voltage 630 V Rated voltage when using spacer plates and mounted 800 V on a conductive housing panel Rated voltage when using spacer plates and adapter plates, and when mounting on a conductive housing panel 1000 V Rated current 32 A Current load, max. 41 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Creation date 17.12.2023 18:19:34 Subject to technical changes 2 Data sheet 17381.6 SDK 4/2A/Z GR Technical data Connection data Connection principle Screw connection Number of terminals per pole 2 No. of poles 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 4 mm² Wire cross-section AWG, min. 26 Wire cross-section AWG, max. 10 Stripping length 10 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A4 Sheet thickness min. 1 mm Sheet thickness max. 4 mm Sheet thickness when using spacer plates, min. 1 mm Sheet thickness when using spacer plates, max. 3 mm Thickness of mounting plate, min. 1 Thickness of mounting plate, max. 4 Creation date 17.12.2023 18:19:34 Subject to technical changes 3 Data sheet 17381.6 SDK 4/2A/Z GR Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 18:19:34 Subject to technical changes 4 Data sheet 17381.6 SDK 4/2A/Z GR Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes Creation date 17.12.2023 18:19:34 Subject to technical changes 5 Data sheet 17381.6 SDK 4/2A/Z GR Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter plate 300 V cUL Usegroup B: rated voltage when using the SDK...-VPI moulded plate and the SDK ...-TWI 600 V partition cUL Usegroup B: rated current 30 A cUL Usegroup B: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter plate 30 A cUL Usegroup B: rated current when using the SDK...-VPI moulded plate and the SDK ...-TWI partition 30 A cUL Usegroup C: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter plate 300 V cUL Usegroup C: rated voltage when using the SDK 4-VPI moulded plate or the SDK 4-TWI partition 600 V cUL Usegroup C: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter plate 30 A cUL Usegroup C: rated current when using the SDK 4-VPI moulded plate or the SDK 4-TWI partition 30 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated voltage when using the SDK 4-DP spacer plate 600 V cUL Usegroup D: rated voltage when using the SDK...-DP spacer plate and the SDK ...-AP adapter plate 300 V cUL Usegroup D: rated current 30 A cUL Usegroup D: rated current when using the SDK 4-DP spacer plate 5A cUL Usegroup D: rated current when using the SDK...-DP spacer plate and the SDK ...-AP adapter plate 30 A cUL wire cross-section single-core (rigid) AWG, min. 26 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 26 cUL wire cross-section stranded AWG, max. 10 cUL torque, min. 0.5 Nm cUL torque, max. 1 Nm cUL wire material Cu cUL Recognized 1 Creation date 17.12.2023 18:19:34 Subject to technical changes 6 Data sheet 17381.6 SDK 4/2A/Z GR Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-71:2009 KEMA KEUR approval granted yes KEMA rated voltage 630 V KEMA rated voltage when using spacer plates and mounted on a conductive housing panel 800 V KEMA rated voltage when using spacer plates and adapter plates, and when mounting on a 1000 V conductive housing panel KEMA rated current 32 A KEMA conventional thermal current in free air 41 A KEMA rated impulse voltage (for 250 V without partitions) 6 kV KEMA wire cross-section, min. 0.2 mm² KEMA wire cross-section, max. 6 mm² Creation date 17.12.2023 18:19:34 Subject to technical changes 7 Data sheet 17381.6 SDK 4/2A/Z GR Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated voltage when using the SDK ...-DP spacer plate 300 V UL Usegroup B: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 600 A plate UL Usegroup B: rated current 30 A UL Usegroup B: rated current when using the SDK ...-DP spacer plate 30 A UL Usegroup B: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 30 V plate UL Usegroup C: rated voltage when using the SDK 4-DP spacer plate 300 V UL Usegroup C: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 600 V plate UL Usegroup C: rated current when using the SDK 4-DP spacer plate 30 A UL Usegroup C: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 30 A plate UL Usegroup D: rated voltage 300 V UL Usegroup D: rated voltage when using the SDK 4-VPI moulded plate or the SDK 4-TWI partition 600 V UL Usegroup D: rated current 30 A UL Usegroup D: rated current when using the SDK 4-VPI moulded plate or the SDK 4-TWI partition 5A UL wire cross-section single-core (rigid) AWG, min. 26 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 26 UL wire cross-section stranded AWG, max. 10 UL torque, min. 4.42 Lb In. UL torque, max. 8.85 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 18:19:34 Subject to technical changes 8 Data sheet 17381.6 SDK 4/2A/Z GR Media Creation date 17.12.2023 18:19:34 Subject to technical changes 9 Data sheet 17381.6 SDK 4/2A/Z GR Accessories Outer 6-pole adapter plate Adapter plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17433.6 SDK 4-AP/6 GR 4044211199272 10 ST Set 23.05.2017, spacer plate inside + outside Partition plate, Width: 3 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17431.6 SDK 4-DP GR 4044211199258 50 ST Set: outer flange plate Flange plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17432.6 SDK 4-FP GR 4044211199265 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9410.7 PMC BSTR 8x12/21 WH 4044211154998 210 ST Screwdriver Creation date 17.12.2023 18:19:34 Subject to technical changes 10 Data sheet 17381.6 SDK 4/2A/Z GR Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 17.12.2023 18:19:34 Subject to technical changes 11
17381.6 价格&库存
很抱歉,暂时无法提供与“17381.6”相匹配的价格&库存,您可以联系我们找货
