17387.6
    CONTA-CLIP
    PANEL FEED-THROUGH TERMINAL
17387.6 数据手册
Data sheet 17387.6 SDK 10/2A/Z GR Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated cross-section: 10 mm², Colour: Grey RAL: 7030 Business data Article number 17387.6 Article name SDK 10/2A/Z GR GTIN (EAN) 4044211209803 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 21.38 g Weight per piece (including packaging) 21.4 g Unit of weight G Customs number 85369010 Country of origin EU Prio-Article 17387.6 Product description Panel feed-through terminal Creation date 16.12.2023 20:47:57 Subject to technical changes 1 Data sheet 17387.6 SDK 10/2A/Z GR Technical data Dimensions Length of outer part 32.9 mm Length of inner part 25.1 mm Width of outer part 10.1 mm Width of inner part 10.1 mm Height of outer part 32.6 mm Height of inner part 31 mm Ratings Rated voltage 630 V Rated voltage when using spacer plates and mounted 800 V on a conductive housing panel Rated voltage when using spacer plates and adapter plates, and when mounting on a conductive housing panel 1000 V Rated current 57 A Current load, max. 76 A Rated cross-section 10 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.82 W Creation date 16.12.2023 20:47:57 Subject to technical changes 2 Data sheet 17387.6 SDK 10/2A/Z GR Technical data Connection data Connection principle Screw connection Number of terminals per pole 2 No. of poles 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 16 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 16 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 10 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 6 Stripping length 12 mm Screw head Slotted Screw threading M4 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A6 Sheet thickness min. 1 mm Sheet thickness max. 4 mm Sheet thickness when using spacer plates, min. 1 mm Sheet thickness when using spacer plates, max. 3 mm Thickness of mounting plate, min. 1 Thickness of mounting plate, max. 4 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:47:57 No Subject to technical changes 3 Data sheet 17387.6 SDK 10/2A/Z GR Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 65 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 65 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated voltage when using the SDK 4600 V DP spacer plate cUL Usegroup D: rated current 65 A cUL Usegroup D: rated current when using the SDK 45A DP spacer plate cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 6 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 6 cUL torque, min. 1.2 Nm cUL torque, max. 2.4 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage with feed-through plate max. 1 mm thickness 1000 V KEMA rated voltage with feed-through plate 2-4 mm thickness 800 V KEMA conventional thermal current in free air 57 A KEMA rated impulse voltage (for 250 V without partitions) 6 kV KEMA wire cross-section, min. 0.2 mm² KEMA wire cross-section, max. 16 mm² KEMA torque, max. 1.2 Nm Creation date 16.12.2023 20:47:57 Subject to technical changes 4 Data sheet 17387.6 SDK 10/2A/Z GR Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 600 A plate UL Usegroup B: rated current 65 A UL Usegroup B: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 65 V plate UL Usegroup C: rated voltage 300 V UL Usegroup C: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 600 V plate UL Usegroup C: rated current 65 A UL Usegroup C: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 65 A plate UL Usegroup D: rated voltage 300 V UL Usegroup D: rated voltage when using the SDK 4-DP spacer plate 600 V UL Usegroup D: rated current 65 A UL Usegroup D: rated current when using the SDK 4-DP spacer plate 5A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 6 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 6 UL torque, min. 10.6 Lb In. UL torque, max. 21.2 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:47:57 Subject to technical changes 5 Data sheet 17387.6 SDK 10/2A/Z GR Media Creation date 16.12.2023 20:47:57 Subject to technical changes 6 Data sheet 17387.6 SDK 10/2A/Z GR Accessories Outer 6-pole adapter plate Adapter plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17443.6 SDK 10-AP/6 GR 4044211209834 10 ST Set 23.05.2017, spacer plate inside + outside Partition plate, Width: 3 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17441.6 SDK 10-DP GR 4044211209810 50 ST Set: outer flange plate Flange plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17442.6 SDK 10-FP GR 4044211209827 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 10 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9433.7 PMC BSTR 10x12/10 WH 4044211155223 100 ST Screwdriver Creation date 16.12.2023 20:47:57 Subject to technical changes 7 Data sheet 17387.6 SDK 10/2A/Z GR Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Creation date 16.12.2023 20:47:57 Subject to technical changes 8
17387.6 价格&库存
很抱歉,暂时无法提供与“17387.6”相匹配的价格&库存,您可以联系我们找货
