17388.6
17388.6
    CONTA-CLIP
    PANEL FEED-THROUGH TERMINAL
17388.6 数据手册
Data sheet 17388.6 SDK 10/1A/1L GR Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated cross-section: 10 mm², Colour: Grey RAL: 7032 Business data Article number 17388.6 Article name SDK 10/1A/1L GR GTIN (EAN) 4044211209889 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 21.18 g Weight per piece (including packaging) 21.2 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Panel feed-through terminal Colour Grey Creation date 16.12.2023 20:48:14 Subject to technical changes 1 Data sheet 17388.6 SDK 10/1A/1L GR Technical data Dimensions Length of outer part 32.9 mm Length of inner part 9.3 mm Width of outer part 10.1 mm Width of inner part 10.1 mm Height of outer part 32.6 mm Height of inner part 22.2 mm Ratings Rated voltage 320 V Rated voltage when used without outer spacer plates, and when mounted on a conductive housing panel 630 V with use of encapsulation compound or inner partition plates Rated voltage when used with outer spacer plates, and when mounted on a conductive housing panel 1000 V with use of encapsulation compound or inner partition plates Rated current 57 A Current load, max. 76 A Rated cross-section 10 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.82 W Creation date 16.12.2023 20:48:14 Subject to technical changes 2 Data sheet 17388.6 SDK 10/1A/1L GR Technical data Connection data Connection principle Screw connection Number of terminals per pole 2 No. of poles 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 16 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 16 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 10 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 6 Stripping length 12 mm Screw head Slotted Screw threading M4 Tightening torque, min. 1.2 Nm Tightening torque, max. 2.4 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A6 Sheet thickness min. 1 mm Sheet thickness max. 4 mm Sheet thickness when using spacer plates, min. 1 mm Sheet thickness when using spacer plates, max. 3 mm Thickness of mounting plate, min. 1 Thickness of mounting plate, max. 4 Creation date 16.12.2023 20:48:14 Subject to technical changes 3 Data sheet 17388.6 SDK 10/1A/1L GR Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:48:14 Subject to technical changes 4 Data sheet 17388.6 SDK 10/1A/1L GR Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated voltage when using the SDK 4DP spacer plate and the SDK 4-VPI moulded plate or 600 V the SDK 4-TWI partition cUL Usegroup B: rated current 65 A cUL Usegroup B: rated current when using the SDK 4DP spacer plate and the SDK 4-VPI moulded plate or 85 A the SDK 4-TWI partition cUL Usegroup C: rated voltage when using the SDK 4DP spacer plate and the SDK 4-VPI moulded plate or 600 V the SDK 4-TWI partition cUL Usegroup C: rated current when using the SDK 4DP spacer plate and the SDK 4-VPI moulded plate or 85 A the SDK 4-TWI partition cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated voltage when using the SDK 4600 V VPI moulded plate or the SDK 4-TWI partition cUL Usegroup D: rated current 65 A cUL Usegroup D: rated current when using the SDK 45A VPI moulded plate or the SDK 4-TWI partition cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 6 cUL wire cross-section stranded AWG, min. 20 cUL wire cross-section stranded AWG, max. 6 cUL torque, min. 1.2 Nm cUL torque, max. 2.4 Nm cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 20:48:14 Subject to technical changes 5 Data sheet 17388.6 SDK 10/1A/1L GR Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage with feed-through plate max. 1mm thickness 1000 V KEMA rated voltage with feed-through plate 2-4 mmthickness 800 V KEMA conventional thermal current in free air 57 A KEMA rated impulse voltage (for 250 V without partitions) 6 kV KEMA wire cross-section, min. 0.2 mm² KEMA wire cross-section, max. 16 mm² KEMA torque, max. 1.2 Nm Creation date 16.12.2023 20:48:14 Subject to technical changes 6 Data sheet 17388.6 SDK 10/1A/1L GR Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-VPI moulded plate or the SDK 4-TWI partition 600 V UL Usegroup B: rated current 65 A UL Usegroup B: rated current when using the SDK 4-DP spacer plate and the SDK 4-VPI moulded plate or the SDK 4-TWI partition 85 A UL Usegroup C: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-VPI moulded 600 V plate or the SDK 4-TWI partition UL Usegroup C: rated current when using the SDK 4-DP spacer plate and the SDK 4-VPI moulded plate or the SDK 4-TWI partition 85 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated voltage when using the SDK 4-VPI moulded plate or the SDK 4-TWI partition 600 V UL Usegroup D: rated current 65 A UL Usegroup D: rated current when using the SDK 4-VPI moulded plate or the SDK 4-TWI partition 5 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 6 UL wire cross-section stranded AWG, min. 20 UL wire cross-section stranded AWG, max. 6 UL torque, min. 10.6 Lb In. UL torque, max. 21.2 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:48:14 Subject to technical changes 7 Data sheet 17388.6 SDK 10/1A/1L GR Media Creation date 16.12.2023 20:48:14 Subject to technical changes 8 Data sheet 17388.6 SDK 10/1A/1L GR Accessories Outer 6-pole adapter plate Adapter plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17443.6 SDK 10-AP/6 GR 4044211209834 10 ST Inner mounting screw Screw, Colour: natural Article number Article name GTIN (EAN) Packaging unit 17448.6 BS-SDK 10/16 4x14 4044211210083 100 ST Set: outer flange plate Flange plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17442.6 SDK 10-FP GR 4044211209827 50 ST Perforated foam seal Seal, Colour: Dark grey Article number Article name GTIN (EAN) Packaging unit 17446.4 SDK 10-SPI/10 DG 4044211210052 100 ST Quick marking Creation date 16.12.2023 20:48:14 Subject to technical changes 9 Data sheet 17388.6 SDK 10/1A/1L GR Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 10 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9433.7 PMC BSTR 10x12/10 WH 4044211155223 100 ST Inner partition plate, solder connection Partition, Width: 6.4 mm, Color: Red Article number Article name GTIN (EAN) Packaging unit 17445.9 SDK 10-TWI RD 4044211210069 50 ST Inner moulded plate Partition plate, Width: 10.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17447.6 SDK 10-VPI GR 4044211210076 50 ST Creation date 16.12.2023 20:48:14 Subject to technical changes 10
17388.6 价格&库存
很抱歉,暂时无法提供与“17388.6”相匹配的价格&库存,您可以联系我们找货
  • 1+74.882891+9.69510
