17397.6
17397.6
    CONTA-CLIP
    PANEL FEED-THROUGH TERMINAL
17397.6 数据手册
Data sheet 17397.6 SDK 16/1A/1B/Z GR Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated cross-section: 16 mm², Colour: Grey RAL: 7032 Business data Article number 17397.6 Article name SDK 16/1A/1B/Z GR GTIN (EAN) 4044211210625 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 27.12 g Weight per piece (including packaging) 27.52 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Panel feed-through terminal Colour Grey Creation date 16.12.2023 20:49:11 Subject to technical changes 1 Data sheet 17397.6 SDK 16/1A/1B/Z GR Technical data Dimensions Length of outer part 37.2 mm Length of inner part 9.3 mm Width of outer part 12 mm Width of inner part 12 mm Height of outer part 41.3 mm Height of inner part 28 mm Ratings Rated voltage 400 V Rated voltage when used without outer spacer plates, and when mounted on a conductive housing panel 630 V with use of encapsulation compound or inner partition plates Rated voltage when used with outer spacer plates, and when mounted on a conductive housing panel 1000 V with use of encapsulation compound or inner partition plates Rated current 76 A Current load, max. 101 A Rated cross-section 16 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.43 W Creation date 16.12.2023 20:49:11 Subject to technical changes 2 Data sheet 17397.6 SDK 16/1A/1B/Z GR Technical data Connection data Connection principle Screw connection Number of terminals per pole 2 No. of poles 1 Wire cross-section single-core (rigid) / stranded, min. 1.5 mm² Wire cross-section single core (rigid)/stranded, max. 25 mm² Wire cross-section stranded, min. 1.5 mm² Wire cross-section stranded, max. 25 mm² Wire cross-section stranded with wire-end ferrules,min. 1.5 mm² Wire cross-section stranded with wire-end ferrules,max. 16 mm² Wire cross-section AWG, min. 16 Wire cross-section AWG, max. 4 Stripping length 16 mm Screw head Slotted Screw threading M5 Screw head inner part Cross-head Screw thread inner part M5 Tightening torque, min. 2 Nm Tightening torque, max. 4 Nm Screw inner part: tightening torque, min. 2.5 Nm Screw inner part: tightening torque, max. 3 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A7 Sheet thickness min. 1 mm Sheet thickness max. 6 mm Sheet thickness when using spacer plates, min. 1 mm Sheet thickness when using spacer plates, max. 5 mm Thickness of mounting plate, min. 1 Thickness of mounting plate, max. 6 Creation date 16.12.2023 20:49:11 Subject to technical changes 3 Data sheet 17397.6 SDK 16/1A/1B/Z GR Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:49:11 Subject to technical changes 4 Data sheet 17397.6 SDK 16/1A/1B/Z GR Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated voltage when using the SDK 4600 V DP spacer plate and the SDK 4-AP adapter plate cUL Usegroup B: rated current 5A cUL Usegroup B: rated current when using the SDK 485 A DP spacer plate and the SDK 4-AP adapter plate cUL Usegroup C: rated voltage when using the SDK 4600 V DP spacer plate and the SDK 4-AP adapter plate cUL Usegroup C: rated current when using the SDK 485 A DP spacer plate and the SDK 4-AP adapter plate cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated voltage when using the SDK 4600 V DP spacer plate cUL Usegroup D: rated current 5A cUL Usegroup D: rated current when using the SDK 485 A DP spacer plate cUL wire cross-section single-core (rigid) AWG, min. 16 cUL wire cross-section single-core (rigid) AWG, max. 4 cUL wire cross-section stranded AWG, min. 16 cUL wire cross-section stranded AWG, max. 4 cUL torque, min. 2 Nm cUL torque, max. 4 Nm cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 20:49:11 Subject to technical changes 5 Data sheet 17397.6 SDK 16/1A/1B/Z GR Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage with feed-through plate 1-2 mmthickness 100 V KEMA rated voltage with feed-through plate max. 3-5mm thickness 800 V KEMA rated voltage with feed-through plate 6 mmthickness 630 V KEMA conventional thermal current in free air 76 A KEMA rated impulse voltage (for 250 V without partitions) 6 kV KEMA wire cross-section, min. 1.5 mm² KEMA wire cross-section, max. 25 mm² KEMA torque, max. 2 Nm Creation date 16.12.2023 20:49:11 Subject to technical changes 6 Data sheet 17397.6 SDK 16/1A/1B/Z GR Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 600 A plate UL Usegroup B: rated current 5A UL Usegroup B: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 85 V plate UL Usegroup C: rated voltage when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 600 V plate UL Usegroup C: rated current when using the SDK 4-DP spacer plate and the SDK 4-AP adapter 85 A plate UL Usegroup D: rated voltage 300 V UL Usegroup D: rated voltage when using the SDK 4-DP spacer plate 600 V UL Usegroup D: rated current 5A UL Usegroup D: rated current when using the SDK 4-DP spacer plate 85 A UL wire cross-section single-core (rigid) AWG, min. 16 UL wire cross-section single-core (rigid) AWG, max. 4 UL wire cross-section stranded AWG, min. 16 UL wire cross-section stranded AWG, max. 4 UL torque, min. 17.7 Lb In. UL torque, max. 35.4 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:49:11 Subject to technical changes 7 Data sheet 17397.6 SDK 16/1A/1B/Z GR Media Creation date 16.12.2023 20:49:11 Subject to technical changes 8 Data sheet 17397.6 SDK 16/1A/1B/Z GR Accessories Outer 6-pole adapter plate Partition plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17453.6 SDK 16-AP/6 GR 4044211210656 10 ST Outer spacer plate Partition plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17454.6 SDK 16-DPA GR 4044211210663 50 ST Set: outer flange plate Flange plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17452.6 SDK 16-FP GR 4044211210649 50 ST Perforated foam seal Seal, Colour: Dark grey Article number Article name GTIN (EAN) Packaging unit 17456.4 SDK 16-SPI/10 DG 4044211210687 100 ST Quick marking Creation date 16.12.2023 20:49:11 Subject to technical changes 9 Data sheet 17397.6 SDK 16/1A/1B/Z GR Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 10 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9433.7 PMC BSTR 10x12/10 WH 4044211155223 100 ST Inner partition plate, solder connection Partition, Width: 6.4 mm, Color: Red Article number Article name GTIN (EAN) Packaging unit 17455.9 SDK 16-TWI RD 4044211210670 50 ST Inner moulded plate Partition plate, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17457.6 SDK 16-VPI GR 4044211210694 50 ST Creation date 16.12.2023 20:49:11 Subject to technical changes 10
17397.6 价格&库存
很抱歉,暂时无法提供与“17397.6”相匹配的价格&库存,您可以联系我们找货
  • 100+37.79117100+4.73909
