Data sheet
17400.8 FIQI 2,5-4/10 YE
Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.4 mm, Colour: Yellow
RAL: 1026
Business data
Article number
17400.8
Article name
FIQI 2,5-4/10 YE
GTIN (EAN)
4044211175948
Packaging unit
10
Quantity unit
PC
Weight per piece (not including packaging)
5.6 g
Weight per piece (including packaging)
5.7 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Product description
Colour
Yellow
Creation date 16.12.2023 20:49:19
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
3.4 mm
Width
50.4 mm
Pitch size
5.1 mm
Ratings
Max. voltage
800 V
Rated current
24 A
Current load, max.
32 A
Rated cross-section
2.5 mm²
Contamination degree
2
Connection data
No. of poles
10
Materials
Material
Bronze
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
10
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Neutral-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,
Rated cross-section: 4 mm², Width: 5.1 mm, Colour: Blue
Article number
Article name
GTIN (EAN)
Packaging
unit
3273.5
FNT 2,5-4 BU
4044211138974
100 ST
Feed-through installation terminal, Push-in connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 4 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3276.2
FRKI 2,5-4 BG
4044211139001
100
4
很抱歉,暂时无法提供与“17400.8”相匹配的价格&库存,您可以联系我们找货
