17444.6
17444.6
    CONTA-CLIP
    PARTITION PLATE
17444.6 数据手册
Data sheet 17444.6 SDK 10-DPA GR Partition plate, Width: 3 mm, Colour: Grey RAL: 7032 Business data Article number 17444.6 Article name SDK 10-DPA GR GTIN (EAN) 4044211210038 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 1.44 g Weight per piece (including packaging) 1.45 g Unit of weight G Customs number 85389099 Country of origin DE Product description Partition plate Colour Grey Creation date 16.12.2023 20:44:24 Subject to technical changes 1 Data sheet 17444.6 SDK 10-DPA GR Technical data Dimensions Length 32.87 mm Width 3 mm Height 32.6 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:44:24 Subject to technical changes 2 Data sheet 17444.6 SDK 10-DPA GR Media Creation date 16.12.2023 20:44:24 Subject to technical changes 3 Data sheet 17444.6 SDK 10-DPA GR Accessories ##INVERSE##CONTA-CON Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17388.6 SDK 10/1A/1L GR 4044211209889 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17389.6 SDK 10/1A/1L/Z GR 4044211209896 50 ST ##INVERSE##CONTA-CON Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17389.6 SDK 10/1A/1L/Z GR 4044211209896 50 ST Creation date 16.12.2023 20:44:24 Subject to technical changes 4
17444.6 价格&库存
很抱歉,暂时无法提供与“17444.6”相匹配的价格&库存,您可以联系我们找货
