17454.6
17454.6
    CONTA-CLIP
    PARTITION PLATE
17454.6 数据手册
Data sheet 17454.6 SDK 16-DPA GR Partition plate, Colour: Grey RAL: 7032 Business data Article number 17454.6 Article name SDK 16-DPA GR GTIN (EAN) 4044211210663 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.2 g Weight per piece (including packaging) 2.3 g Unit of weight G Customs number 85389099 Country of origin DE Product description Partition plate Colour Grey Creation date 16.12.2023 20:30:30 Subject to technical changes 1 Data sheet 17454.6 SDK 16-DPA GR Technical data Dimensions Length 37.2 mm Width 3 mm Height 41.3 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:30:30 Subject to technical changes 2 Data sheet 17454.6 SDK 16-DPA GR Media Creation date 16.12.2023 20:30:30 Subject to technical changes 3 Data sheet 17454.6 SDK 16-DPA GR Accessories ##INVERSE##CONTA-CON Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 16 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17396.6 SDK 16/1A/1B GR 4044211210618 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 16 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17397.6 SDK 16/1A/1B/Z GR 4044211210625 50 ST ##INVERSE##CONTA-CON Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 16 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17396.6 SDK 16/1A/1B GR 4044211210618 50 ST Creation date 16.12.2023 20:30:30 Subject to technical changes 4
17454.6 价格&库存
很抱歉,暂时无法提供与“17454.6”相匹配的价格&库存,您可以联系我们找货
