17523.2
17523.2
    CONTA-CLIP
    TEST DISCONNECT TERMINAL
17523.2 数据手册
Data sheet 17523.2 SPTK 6/LT/HB BG Test disconnect terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 6 mm², Width: 8.1 mm, Colour: Beige Business data Article number 17523.2 Article name SPTK 6/LT/HB BG GTIN (EAN) 4044211209223 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 28.23 g Weight per piece (including packaging) 28.43 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Test disconnect terminal Colour Beige Creation date 15.12.2023 20:09:23 Subject to technical changes 1 Data sheet 17523.2 SPTK 6/LT/HB BG Technical data Dimensions Length 93 mm Width 8.1 mm Height TS 35/7.5 63 mm Ratings Rated voltage 400 V Rated current 41 A Rated cross-section 6 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.31 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 6 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 8 Stripping length 10 mm Screw head Slotted Screw threading M 3,5 Tightening torque, min. 0.8 Nm Tightening torque, max. 1.6 Nm Creation date 15.12.2023 20:09:23 Subject to technical changes 2 Data sheet 17523.2 SPTK 6/LT/HB BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A5 Number of cross-connection channels 4 End plate required Built-in test socket available Version of lengthwise partition Sliding Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 20:09:23 Subject to technical changes 3 Data sheet 17523.2 SPTK 6/LT/HB BG Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 33 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 33 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 33 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 8 cUL torque, min. 1.2 Nm cUL torque, max. 2 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 41 A KEMA rated impulse voltage 4 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 10 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 10 mm² KEMA torque, min. 0.8 Nm KEMA torque, max. 1.6 Nm Creation date 15.12.2023 20:09:23 Subject to technical changes 4 Data sheet 17523.2 SPTK 6/LT/HB BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 33 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 33 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 33 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 8 UL torque, min. 10.6 Lb In. UL torque, max. 17.7 Lb In. UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 20:09:23 Subject to technical changes 5 Data sheet 17523.2 SPTK 6/LT/HB BG Media Creation date 15.12.2023 20:09:23 Subject to technical changes 6 Data sheet 17523.2 SPTK 6/LT/HB BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17530.2 SAP/L/Q/D BG 4044211209179 20 ST Mounting screw Mounting screw, M 2.5, Colour: Violet Article number Article name GTIN (EAN) Packaging unit 2243.0 BS 25 VT 4044211050665 50 ST Mounting screw, M 2.5, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2241.0 BS 25 YE 4044211050641 50 ST Mounting screw, M 2.5, Colour: Green Article number Article name GTIN (EAN) Packaging unit 2242.0 BS 25 GN 4044211050658 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17250.2 SES 35 BG 4044211178253 50 Insulation cap for cross-connector Creation date 15.12.2023 20:09:23 Subject to technical changes 7 Data sheet 17523.2 SPTK 6/LT/HB BG Insulating cap, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17200.8 SQIK 2,5-10 YE 4044211148539 20 Cross-switch bridge Cross-switch bridge, No. of poles: 10, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17550.3 QVSI 10 OG 4044211209315 20 ST Cross-switch bridge, No. of poles: 5, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17545.3 QVSI 5 OG 4044211209261 20 ST Cross-switch bridge, No. of poles: 7, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17547.3 QVSI 7 OG 4044211209285 20 ST Cross-switch bridge, No. of poles: 9, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17549.3 QVSI 9 OG 4044211209308 20 ST Cross-switch bridge, No. of poles: 4, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17544.3 QVSI 4 OG 4044211209254 50 ST Cross-switch bridge, No. of poles: 6, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17546.3 QVSI 6 OG 4044211209278 20 ST Creation date 15.12.2023 20:09:23 Subject to technical changes 8 Data sheet 17523.2 SPTK 6/LT/HB BG Cross-switch bridge Cross-switch bridge, No. of poles: 3, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17543.3 QVSI 3 OG 4044211209247 50 ST Cross-switch bridge, No. of poles: 2, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17542.3 QVSI 2 OG 4044211209230 50 ST Cross-switch bridge, No. of poles: 8, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17548.3 QVSI 8 OG 4044211209292 20 ST Internal cross-switch bridge Cross-switch bridge, No. of poles: 2, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17534.3 QSBI 2 OG 4044211209452 50 ST Cross-switch bridge, No. of poles: 3, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17535.3 QSBI 3 OG 4044211209469 50 ST Cross-switch bridge, No. of poles: 4, Mounting type: Can be screwed on, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 17536.3 QSBI 4 OG 4044211209476 50 ST Insulated cross-connector Creation date 15.12.2023 20:09:23 Subject to technical changes 9 Data sheet 17523.2 SPTK 6/LT/HB BG Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 54.8 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17226.8 SQI 6/7 YE 4044211148799 20 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 62.9 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17227.8 SQI 6/8 YE 4044211148805 10 Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 30.5 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17223.8 SQI 6/4 YE 4044211148768 20 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 71 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17228.8 SQI 6/9 YE 4044211148812 10 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 79.1 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17229.8 SQI 6/10 YE 4044211148829 10 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 14.3 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17221.8 SQI 6/2 YE 4044211148744 50 Creation date 15.12.2023 20:09:23 Subject to technical changes 10 Data sheet 17523.2 SPTK 6/LT/HB BG Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 22.4 mm,Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17222.8 SQI 6/3 YE 4044211148751 50 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 46.7 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17225.8 SQI 6/6 YE 4044211148782 20 Insulated cross-connector, No. of poles: 30, Mounting type: Plug in, Width: 240 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17230.8 SQI 6/30 YE 4044211148836 5 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 38.6 mm, Rated cross-section: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17224.8 SQI 6/5 YE 4044211148775 20 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Creation date 15.12.2023 20:09:23 Subject to technical changes 11 Data sheet 17523.2 SPTK 6/LT/HB BG Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Insulated long socket plug Insulated socket, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17532.8 STBI 19/4-L YE 4044211209438 50 Short-circuit plug Short-circuit plug, No. of poles: 3, Mounting type: Plug in, Width: 22.4 mm, Rated crosssection: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17553.8 KS-SQI 6/3 YE 4044211209483 50 ST Short-circuit plug, No. of poles: 4, Mounting type: Plug in, Width: 30.5 mm, Rated crosssection: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17554.8 KS-SQI 6/4 YE 4044211209490 50 ST Short-circuit plug, No. of poles: 2, Mounting type: Plug in, Width: 14.3 mm, Rated crosssection: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17552.8 KS-SQI 6/2 YE 4044211209193 50 ST Creation date 15.12.2023 20:09:23 Subject to technical changes 12 Data sheet 17523.2 SPTK 6/LT/HB BG Short-circuit plug Short-circuit plug, No. of poles: 5, Mounting type: Plug in, Width: 38.6 mm, Rated crosssection: 6 mm², Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17555.8 KS-SQI 6/5 YE 4044211209506 20 ST Connecting sleeve Connecting sleeve, Colour: natural Article number Article name GTIN (EAN) Packaging unit 2238.0 VH 19 4044211050610 50 ST Creation date 15.12.2023 20:09:23 Subject to technical changes 13
17523.2 价格&库存
很抱歉,暂时无法提供与“17523.2”相匹配的价格&库存,您可以联系我们找货
  • 50+77.3662050+10.02030
