2001.6
    CONTA-CLIP
    END PLATE
2001.6 数据手册
Data sheet 2001.6 AP 2,5-10 GR End plate, Width: 1.5 mm, Colour: Grey RAL: 7030 Business data Article number 2001.6 Article name AP 2,5-10 GR GTIN (EAN) 4044211127367 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.2 g Weight per piece (including packaging) 2.29 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2001.2 Product description End plate Creation date 16.12.2023 21:20:40 Subject to technical changes 1 Data sheet 2001.6 AP 2,5-10 GR Technical data Dimensions Length 48 mm Width 1.5 mm Min. thickness 1.5 mm Height 31.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 21:20:40 No Subject to technical changes 2 Data sheet 2001.6 AP 2,5-10 GR Media Creation date 16.12.2023 21:20:40 Subject to technical changes 3 Data sheet 2001.6 AP 2,5-10 GR Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Faston Spade connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1014.2 FF 2,5 BG 4044211003203 100 Feed-through terminal, Faston Spade connection / screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1019.2 SF 2,5-4 BG 4044211004323 100 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17111.2 SSL 6/2A GNYE 4044211141769 100 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17103.2 SSL 2,5/2A GNYE 4044211141684 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17106.2 SRK 4/2A/Z BG 4044211141714 100 ST Creation date 16.12.2023 21:20:40 Subject to technical changes 4 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17107.2 SSL 4/2A GNYE 4044211141721 100 ST Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 17115.2 SSL 10/2A GNYE 4044211141806 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17132.2 SRK 6/2A/PE BKYE 4044211200718 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17100.2 SRK 2,5/2A BG 4044211141653 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17113.2 SRK B 10/2A BG 4044211141783 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17129.2 SRK 2,5/2A/PE BKYE 4044211200688 100 ST Creation date 16.12.2023 21:20:40 Subject to technical changes 5 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17155.2 SRK 4/2A/PE BKYE 4044211186692 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17104.2 SRK 4/2A BG 4044211141691 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17105.2 SRK B 4/2A BG 4044211141707 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17109.2 SRK B 6/2A BG 4044211141745 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17112.2 SRK 10/2A BG 4044211141776 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17119.2 SRK 2,5/2A SAS BG 4044211149048 80 Creation date 16.12.2023 21:20:40 Subject to technical changes 6 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17101.2 SRK B 2,5/2A BG 4044211141660 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17102.2 SRK 2,5/2A/Z BG 4044211141677 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17108.2 SRK 6/2A BG 4044211141738 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17110.2 SRK 6/2A/Z BG 4044211141752 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17114.2 SRK 10/2A/Z BG 4044211141790 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17117.2 SRK 6/2A SAS BG 4044211149000 80 Creation date 16.12.2023 21:20:40 Subject to technical changes 7 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17118.2 SRK 10/2A SAS BG 4044211149024 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17116.2 SRK 4/2A SAS BG 4044211148980 80 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 17133.2 SRK 10/2A/PE BKYE 4044211200725 100 ST Terminal block for temperature measuring circuits, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1200.2 TSK 2,5/T BG 4044211027667 50 ST Terminal block for temperature measuring circuits, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1201.2 TSK 2,5/J BG 4044211027803 50 ST Creation date 16.12.2023 21:20:40 Subject to technical changes 8 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Terminal block for temperature measuring circuits, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1203.2 TSK 2,5/K BG 4044211028022 50 ST Terminal block for temperature measuring circuits, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1205.2 TSK 2,5/R BG 4044211028060 50 ST Terminal block for temperature measuring circuits, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1204.2 TSK 2,5/S BG 4044211028046 50 ST Four-wire motor-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1520.2 VMAB 2,5 4044211046613 10 ST Four-wire motor-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1521.2 VMAB 2,5-4 4044211046682 10 ST Creation date 16.12.2023 21:20:40 Subject to technical changes 9 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Five-wire mains-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1524.2 FNAB 2,5-4 4044211046781 10 ST Five-wire mains-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1525.2 FNAB 6-10 4044211046804 10 ST Five-wire mains-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1523.2 FNAB 2,5 4044211046729 10 ST Four-wire motor-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1522.2 VMAB 6-10 4044211046699 10 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1168.2 RK 6-10/35/SAS BG 4044211128630 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1001.2 RK 2,5-4 BG 4044211000240 100 Creation date 16.12.2023 21:20:40 Subject to technical changes 10 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1296.2 RK 2,5 BG 4044211040215 100 Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1432.2 RK 35 Ex BG 4044211044794 20 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 1563.2 RK 2,5-4/PE BKYE 4044211047344 100 ST Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1430.2 RK 6-10 Ex BG 4044211044770 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 1748.4 RK 2,5-4 PA-G BK 4044211141134 100 ST Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 25 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1166.2 RK 2,5/SAS BG 4044211128616 100 Creation date 16.12.2023 21:20:40 Subject to technical changes 11 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1167.2 RK 2,5-4/35/SAS BG 4044211128623 100 Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1427.2 RK 2,5-4 Ex BG 4044211044732 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1005.2 RK 6-10 BG 4044211001148 100 Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1426.2 RK 2,5 Ex BG 4044211044718 100 Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 16 mm², Width: 12 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1431.2 RK 16 Ex BG 4044211044787 50 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1577.2 RK 2,5-4/35 BG 4044211047566 100 Creation date 16.12.2023 21:20:40 Subject to technical changes 12 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 25 mm², Width: 5 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 1562.2 RK 2,5/PE BKYE 4044211047337 100 ST Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 1564.2 RK 6-10/PE BKYE 4044211047351 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1578.2 RK 6-10/35 BG 4044211047627 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 1749.4 RK 6-10 PA-G BK 4044211141141 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87807.2 SRK 10/2A Ex BG 4044211199807 100 Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87805.2 SRK 6/2A Ex BG 4044211199777 100 Creation date 16.12.2023 21:20:40 Subject to technical changes 13 Data sheet 2001.6 AP 2,5-10 GR ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 87805.2 SRK 6/2A Ex BG 4044211199777 100 Creation date 16.12.2023 21:20:40 Subject to technical changes 14
2001.6 价格&库存
很抱歉,暂时无法提供与“2001.6”相匹配的价格&库存,您可以联系我们找货
    • 50+6.4203950+0.79895
