2046.3
2046.3
    CONTA-CLIP
    END PLATE
2046.3 数据手册
Data sheet 2046.3 AP SI-1 OG End plate, Width: 1.5 mm, Colour: Orange Business data Article number 2046.3 Article name AP SI-1 OG GTIN (EAN) 4044211107789 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 1.95 g Weight per piece (including packaging) 1.96 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2046.2 Product description End plate Creation date 16.12.2023 21:19:17 Subject to technical changes 1 Data sheet 2046.3 AP SI-1 OG Technical data Dimensions Length 52.5 mm Width 1.5 mm Min. thickness 1.5 mm Height 22.8 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 21:19:17 No Subject to technical changes 2 Data sheet 2046.3 AP SI-1 OG Media Creation date 16.12.2023 21:19:17 Subject to technical changes 3 Data sheet 2046.3 AP SI-1 OG Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2451.2 STK 1/LED(RD)/60V DC BG 4044211052416 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2457.2 STK 1/LED(RD)/115V AC BG 4044211052478 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2190.2 STK 1 BG 4044211050115 100 Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2452.2 STK 1/LED(RD)/115V DC BG 4044211052423 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2454.2 STK 1/LED(RD)/24V AC BG 4044211052447 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2455.2 STK 1/LED(RD)/48V AC BG 4044211052454 100 ST Creation date 16.12.2023 21:19:17 Subject to technical changes 4 Data sheet 2046.3 AP SI-1 OG ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2449.2 STK 1/LED(RD)/24V DC BG 4044211052393 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2453.2 STK 1/LED(RD)/230V DC BG 4044211052430 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2458.2 STK 1/LED(RD)/230V AC BG 4044211052485 100 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2456.2 STK 1/LED(RD)/60V AC BG 4044211052461 100 ST Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2191.2 STK 1/15 BG 4044211050160 100 Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2450.2 STK 1/LED(RD)/48V DC BG 4044211052409 100 ST Creation date 16.12.2023 21:19:17 Subject to technical changes 5 Data sheet 2046.3 AP SI-1 OG ##INVERSE##CONTA-CONNECT Disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2194.2 TK 2/15/K BG 4044211050214 100 Disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2193.2 TK 2/K BG 4044211050191 100 ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2453.2 STK 1/LED(RD)/230V DC BG 4044211052430 100 ST Creation date 16.12.2023 21:19:17 Subject to technical changes 6
2046.3 价格&库存
很抱歉,暂时无法提供与“2046.3”相匹配的价格&库存,您可以联系我们找货
