Data sheet
2071.5 TW 1,5-4 BU
Partition plate, Width: 1.5 mm, Colour: Blue
RAL: Ähnlich 5005
Business data
Article number
2071.5
Article name
TW 1,5-4 BU
GTIN (EAN)
4044211048808
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
1.1 g
Weight per piece (including packaging)
1.11 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
2071.2
Product description
Partition plate
Creation date 16.12.2023 21:15:27
Subject to technical changes
1
Data sheet
2071.5 TW 1,5-4 BU
Technical data
Dimensions
Length
31.5 mm
Width
1.5 mm
Min. thickness
1.5 mm
Height
47 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
2071.5 TW 1,5-4 BU
Media
3
Data sheet
2071.5 TW 1,5-4 BU
Accessories
##INVERSE##CONTA-CONNECT
Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated
cross-section: 4 mm², Width: 6 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1010.2
RK 1,5-4/15 BG
4044211002275
100
Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS
32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1030.2
SRK 2,5 BG
4044211006723
100
32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1015.2
RK 1,5-4 BG
4044211003425
100
Ex feed-through terminal ATEX-certified, Screw connection, Mounting type: Mounting rail
TS 15/5.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1433.2
RK 1,5-4/15 Ex BG
4044211044817
100
4
很抱歉,暂时无法提供与“2071.5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+7.4303050+0.96249
