2104.6
2104.6
    CONTA-CLIP
    END PLATE
2104.6 数据手册
Data sheet 2104.6 AP 16 GR End plate, Width: 1.5 mm, Colour: Grey RAL: 7030 Business data Article number 2104.6 Article name AP 16 GR GTIN (EAN) 4044211127374 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 4.1 g Weight per piece (including packaging) 4.25 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2104.2 Product description End plate Creation date 16.12.2023 21:16:48 Subject to technical changes 1 Data sheet 2104.6 AP 16 GR Technical data Dimensions Length 49.7 mm Width 1.5 mm Min. thickness 1.5 mm Height 47.7 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 21:16:48 No Subject to technical changes 2 Data sheet 2104.6 AP 16 GR Media Creation date 16.12.2023 21:16:48 Subject to technical changes 3 Data sheet 2104.6 AP 16 GR Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 16 mm², Width: 12 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1050.2 RK 16 BG 4044211010522 50 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 16 mm², Width: 12 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1162.2 RK 16/Z BG 4044211023607 50 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 16 mm², Width: 12 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1492.2 RK 16/IS BG 4044211045234 50 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 16 mm², Width: 12 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1493.2 RK 16/Z/IS BG 4044211045258 50 Creation date 16.12.2023 21:16:48 Subject to technical changes 4
2104.6 价格&库存
很抱歉,暂时无法提供与“2104.6”相匹配的价格&库存,您可以联系我们找货
